- To:
- Subject: Re: [cgal-discuss] error regarding file stream
- Date: Wed, 4 Nov 2009 12:05:24 -0800 (PST)
Hi,
Thank you for you quick response and wonderfull suggestion.
It really help for the new developers like me.
I could not get your idea, could you please explain me why it is not
working.
here is my sort version code:
// simple file stream exaple
#include "stdafx.h"
#include <CGAL/property_map.h>
#include <CGAL/IO/read_xyz_points.h>
#include <CGAL/IO/write_xyz_points.h>
#include <CGAL/double.h>
#include <utility> // defines std::pair
#include <vector>
#include <fstream>
#include<iostream>
// types
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_3 Point;
using namespace std;
int main(void)
// Reads a .xyz point set file in points[].
vector<Point> points;
ifstream in("D:/Cgalcode/file/data/tree.xyz");
if (!in ||
!CGAL::read_xyz_points(in,std::back_inserter(points)))
cerr << "Error: cannot read file data/oni.xyz" << std::endl;
return EXIT_FAILURE;
// displaying
for(unsigned int i = 0; i < points.size(); i++)
cout.precision(20);
cout << points[i]<< std::endl;
// Saves point set.
ofstream out("D:/Cgalcode/file/data/tree.xyz");
if (!out ||
!CGAL::write_xyz_points(out, points.begin(), points.end()))
return EXIT_SUCCESS;
input:
257507.81 471326.84 44.99
257507.79 471326.90 44.70
257507.75 471326.93 44.51
output:
257508 471327 44.99
257508 471327 44.7
257508 471327 44.51
Sebastien Loriot wrote:
> pratihast22089 wrote:
>> hi,
>> I am facing one simple problem regarding file stream.
>> I have the data file like this:
>> 257507.77 471326.90 44.49
>> 257507.89 471326.93 44.04
>> 257507.81 471326.81 44.51
>> 257507.89 471326.87 44.10
>> While Reading and writing file stream, it truncate the number behind
>> point
>> of first two columns but not for the third column.
>> output:
>> 257507 471326 44.51
>> 257507 471326 44.49
>> 257507 471326 44.04
>> 257507 471326 44.51
>> 257507 471326 44.10
>> I had included the #include <CGAL/double.h> header file.
>> Could you please help me in this regrads.
>> Thank you in advance.
>> Regards,
>> Arun K Pratihast
> Hello,
> Could you please post a minimal example so that we can reproduce the
> problem encountered.
> S.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
View this message in context:
http://old.nabble.com/error-regarding-file-stream-tp26195935p26203717.html
- [cgal-discuss] error regarding file stream, pratihast22089, 11/04/2009
- Re: [cgal-discuss] error regarding file stream, Sebastien Loriot, 11/04/2009
- Re: [cgal-discuss] error regarding file stream, pratihast22089, 11/04/2009
- Re: [cgal-discuss] error regarding file stream, Andreas Fabri, 11/04/2009
- Re: [cgal-discuss] error regarding file stream, pratihast22089, 11/05/2009
- Re: [cgal-discuss] error regarding file stream, Ariel Baez, 11/04/2009
- Re: [cgal-discuss] error regarding file stream, Olivier Devillers, 11/04/2009
