cgal-discuss - [cgal-discuss] Re: powerdiagram3D
  • To:
  • Subject: [cgal-discuss] Re: powerdiagram3D
  • Date: Mon, 09 Nov 2009 13:22:10 +0100
wrote:
hi, please tell me that how to use it possible to make regular triangulation3D with info? I used : typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Regular_triangulation_filtered_traits_3 Gt; typedef CGAL::Triangulation_vertex_base_with_info_3 Vb; typedef CGAL::Triangulation_data_structure_3 Tds; typedef CGAL::Regular_triangulation_3 Rt; Please tell me what should I use? thanks,
Please have a look at the documentation:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_35.6.2
and please send your emails to the cgal-discuss mailing list as they may
be useful for others.
Sebastien Loriot wrote:
wrote:
hi,
thanks ,I can obtain the points bounding the face,
after obtain the points , convex3d of the points is a face in a power
diagram ,is true?
I do not understand your question.
S.
sara_mahdavi wrote:
hi,
why nobody do answer to Question?
Your question may be more attractive and easy to read
if you had more whitespace and new lines in you request.
If I understand the question, you would like to get a facet
in a power diagram. As you know a facet is the dual of an edge
in the regular triangulation.
Then all finite cells incident to an edge give you the points
bounding the face.
Use the following function to get incident cells:
/Cell_circulator / / t.incident_cells ( Edge e) /(cf. http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html)//
For those that are finite, you can get the dual points using function
/Point// rt.dual ( Cell_handle c)
/S.
if myquestion is easy ,but I don't
know.help me,
thanks
hi ,all
I need powerdiagram3D , there is in manual cgal two function(rt.dual(
Cell
handle c ), rt.dual( Facet f) ) for pd3D,rt.dual( Cell handle c ) give
a
vertex of pd3D,and rt.dual( Facet f) give a edge of pd3D.it is true
that
a
cell of pd3D obtained by convex polyhedron from a tetrahedron,thus I
obtain
cells of pd3D one after one ,I don't know how obtain a face in
pd3D?is
there a code for pd3D ? please help me.
Quoted from: http://old.nabble.com/powerdiagram3D-tp26193589p26193925.html
Quoted from: http://old.nabble.com/powerdiagram3D-tp26193589p26228937.html
