Re:Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set
- To: cgal-discuss <>
- Subject: Re:Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set
- Date: Mon, 9 Nov 2009 23:06:00 +0800 (CST)
你好,我现在做三维场景重建方面的,我用cgal 3.5 中 Surface Reconstruction from Point Set实现的算法来做,在有些数据上没问题,但是有些数据重建之后的图形已经跟原来的图形完全不一样了,刚开始我的点没经过处理,后来我处理之后,重建后的图形还是差不多。。。 我QQ是 770631259
我刚用CGAL不久,以后希望多多指教
在2009-11-09 09:37:29,"杨成林" <> 写道:
看样子你是中国人,你可以直接用中文给我电邮。
2009/11/8 Bo Zhou <>
杨成林 wrote:
I suggest you use the code from the author of Poisson Surface Reconstruction: http://www.cs.jhu.edu/~misha/Code/PoissonRecon/ <http://www.cs.jhu.edu/%7Emisha/Code/PoissonRecon/>.And there is an out of core version:In my opinion, CGAL's implementation is just a general version, so the performance could not be as high as a specific one.
http://www.cs.jhu.edu/~bolitho/Research/StreamingSurfaceReconstruction/ <http://www.cs.jhu.edu/%7Ebolitho/Research/StreamingSurfaceReconstruction/>.
2009/11/7 < <mailto:>>
Hi ,there
I'm very glad that CGAL-3.5 provides such a package, with which we can
reconstruct surface point set easily.But in my project there're a
large number
of point set,100,000 or even 1,000,000 in total.I wonder how i can
improve the
performace of my program or whether the package is proper for my
project.
I will really apperciate your help.
杨成林
Yang Chenglin
杨成林
Yang Chenglin
网易历六年耗亿资打造,3D国韵网游《天下贰》,免费领光盘
- [cgal-discuss] how to improve the performace when reconstruct surface from point set, zengdeshou, 11/07/2009
- Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set, 杨成林, 11/07/2009
- Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set, Bo Zhou, 11/08/2009
- Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set, 杨成林, 11/09/2009
- Re:Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set, zengdeshou, 11/09/2009
- Re: [cgal-discuss] how to improve the performace when reconstruct surface from point set, Pierre Alliez, 11/09/2009
