- To:
- Subject: Re: [cgal-discuss] Installation of CGAL 3.5
- Date: Wed, 11 Nov 2009 11:04:43 +0300
> What version of CMake do you use, by the way?
CMake 2.6-patch 4
> Can you attach you CMakeCache.txt file? It should have been generated
> during
> the attempt of configuration by CMake.
Done - Attached.
# This is the CMakeCache file.
# For build in directory: c:/devel/tools/CGAL-3.5
# It was generated by CMake: C:/Program Files (x86)/CMake 2.6/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Path to a file.
Boost_INCLUDE_DIR:PATH=C:/devel/tools/boost_1_40_0
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//Path to a library.
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=Boost_THREAD_LIBRARY_DEBUG-NOTFOUND
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=Boost_THREAD_LIBRARY_RELEASE-NOTFOUND
//Value Computed by CMake
CGAL_BINARY_DIR:STATIC=C:/devel/tools/CGAL-3.5
//User-defined flags
CGAL_CXX_FLAGS:STRING= -frounding-math
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
//The folder where CGAL user-side scripts will be installed, relative
// to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_BIN_DIR:STRING=script
//The folder where CGAL CMake modules will be installed, relative
CGAL_INSTALL_CMAKE_DIR:STRING=cmake/modules
//The folder where CGAL header files will be installed, relative
CGAL_INSTALL_INC_DIR:STRING=include
//The folder where CGAL libraries will be installed, relative to
// CMAKE_INSTALL_PREFIX
CGAL_INSTALL_LIB_DIR:STRING=lib
//The folder where CGAL documentation and license files will be
// installed, relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_ROOT_DIR:STRING=.
CGAL_ImageIO_BINARY_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALimageIO
//The CGAL_ImageIO library
CGAL_ImageIO_LIBRARY:STRING=C:/devel/tools/CGAL-3.5/lib/libCGAL_ImageIO.a
//Dependencies for the target
CGAL_ImageIO_LIB_DEPENDS:STATIC=general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;general;glu32;general;opengl32;general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;
CGAL_ImageIO_SOURCE_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALimageIO
//Dependencies for target
CGAL_LIB_DEPENDS:STATIC=
CGAL_PDB_BINARY_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALPDB
//The CGAL_PDB library
CGAL_PDB_LIBRARY:STRING=C:/devel/tools/CGAL-3.5/lib/libCGAL_PDB.a
CGAL_PDB_LIB_DEPENDS:STATIC=general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;
CGAL_PDB_SOURCE_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALPDB
CGAL_Qt3_BINARY_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALQt
CGAL_Qt3_SOURCE_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALQt
CGAL_Qt4_BINARY_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALQt4
//The CGAL_Qt4 library
CGAL_Qt4_LIBRARY:STRING=C:/devel/tools/CGAL-3.5/lib/libCGAL_Qt4.a
CGAL_Qt4_LIB_DEPENDS:STATIC=general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;general;C:/devel/tools/CGAL-3.5/lib/libCGAL.a;optimized;C:/devel/Qt/4.6.0-beta1/lib/libqtmain.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libqtmaind.a;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGL4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGLd4.a;general;-lopengl32
-lglu32 -lgdi32
-luser32;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtGui4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtGuid4.a;general;imm32;general;winmm;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtCore4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtCored4.a;general;ws2_32;general;glu32;general;opengl32;
CGAL_Qt4_SOURCE_DIR:STATIC=C:/devel/tools/CGAL-3.5/src/CGALQt4
//soname-version
CGAL_SONAME_VERSION:STRING=4
CGAL_SOURCE_DIR:STATIC=C:/devel/tools/CGAL-3.5
//soversion
CGAL_SOVERSION:STRING=4.0.0
//Path to a program.
CMAKE_AR:FILEPATH=C:/devel/MinGW/bin/ar.exe
//For backwards compatibility, what version of CMake commands and
// syntax should this version of CMake try to support.
CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Release
//Enable/Disable color output during build.
CMAKE_COLOR_MAKEFILE:BOOL=ON
//CXX compiler.
CMAKE_CXX_COMPILER:FILEPATH=c:/devel/MinGW/bin/g++.exe
CMAKE_CXX_FLAGS:STRING= -frounding-math
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=-g
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
//Libraries linked by defalut with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING=-lkernel32 -luser32 -lgdi32 -lwinspool
-lshell32 -lole32 -loleaut32 -luuid -lcomdlg32 -ladvapi32
//C compiler.
CMAKE_C_COMPILER:FILEPATH=C:/devel/MinGW/bin/gcc.exe
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING=
CMAKE_C_FLAGS_DEBUG:STRING=-g
CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
// files).
CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
//Libraries linked by defalut with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING=-lkernel32 -luser32 -lgdi32 -lwinspool
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files (x86)/CGAL
CMAKE_LINKER:FILEPATH=C:/devel/MinGW/bin/ld.exe
CMAKE_MAKE_PROGRAM:FILEPATH=C:/devel/MinGW/bin/mingw32-make.exe
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_NM:FILEPATH=C:/devel/MinGW/bin/nm.exe
CMAKE_OBJCOPY:FILEPATH=C:/devel/MinGW/bin/objcopy.exe
CMAKE_OBJDUMP:FILEPATH=C:/devel/MinGW/bin/objdump.exe
CMAKE_RANLIB:FILEPATH=C:/devel/MinGW/bin/ranlib.exe
CMAKE_SH:FILEPATH=CMAKE_SH-NOTFOUND
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
CMAKE_STRIP:FILEPATH=C:/devel/MinGW/bin/strip.exe
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//The directory containing the GMP header files
GMP_INCLUDE_DIR:PATH=C:/devel/tools/CGAL-3.5/auxiliary/gmp/include
//Path to the GMP library
GMP_LIBRARIES:FILEPATH=GMP_LIBRARIES-NOTFOUND
//The directory containing the MPFR header files
MPFR_INCLUDE_DIR:PATH=C:/devel/tools/CGAL-3.5/auxiliary/gmp/include
//Path to the MPFR library
MPFR_LIBRARIES:FILEPATH=MPFR_LIBRARIES-NOTFOUND
//OpenGL library for win32
OPENGL_gl_LIBRARY:STRING=opengl32
//GLU library for win32
OPENGL_glu_LIBRARY:STRING=glu32
//path to qt3 include directory
QT3_INCLUDE_DIR:PATH=QT3_INCLUDE_DIR-NOTFOUND
QT3_MOC_EXECUTABLE:FILEPATH=c:/devel/Qt/4.6.0-beta1/bin/moc.exe
QT3_QASSISTANTCLIENT_LIBRARY:FILEPATH=QT3_QASSISTANTCLIENT_LIBRARY-NOTFOUND
//This Library is only needed by and included with Qt3 on MSWindows.
// It should be NOTFOUND, undefined or IGNORE otherwise.
QT3_QTMAIN_LIBRARY:FILEPATH=QT3_QTMAIN_LIBRARY-NOTFOUND
QT3_QT_LIBRARY:FILEPATH=QT3_QT_LIBRARY-NOTFOUND
QT3_UIC_EXECUTABLE:FILEPATH=c:/devel/Qt/4.6.0-beta1/bin/uic.exe
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
//The location of the Qt docs
QT_DOC_DIR:PATH=C:/devel/Qt/4.6.0-beta1/doc
//Missing description
QT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include
//Qt library dir
QT_LIBRARY_DIR:PATH=C:/devel/Qt/4.6.0-beta1/lib
QT_LRELEASE_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/lrelease.exe
QT_LUPDATE_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/lupdate.exe
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=C:/devel/Qt/4.6.0-beta1/mkspecs
//The moc executable
QT_MOC_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/moc.exe
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/phonon
QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND
QT_PHONON_LIBRARY_RELEASE:FILEPATH=QT_PHONON_LIBRARY_RELEASE-NOTFOUND
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=C:/devel/Qt/4.6.0-beta1/plugins
QT_QMAKE_EXECUTABLE:FILEPATH=c:/devel/Qt/4.6.0-beta1/bin/qmake.exe
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/Qt3Support
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQt3Support4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQt3Supportd4.a
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQt3Supportd4.a
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQt3Support4.a
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtAssistant
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClient4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClientd4.a
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClientd4.a
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClient4.a
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtAssistant
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClient4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClientd4.a
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClientd4.a
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtAssistantClient4.a
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtCLucene4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtCLucened4.a
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtCLucened4.a
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtCLucene4.a
//Path to a file.
QT_QTCORE_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtCore
//The Qt QTCORE library
QT_QTCORE_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtCore4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtCored4.a
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtCored4.a
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtCore4.a
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtDBus
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerComponents4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerComponentsd4.a
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerComponentsd4.a
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerComponents4.a
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtDesigner4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerd4.a
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtDesignerd4.a
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtDesigner4.a
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtGui4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtGuid4.a
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtGuid4.a
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtGui4.a
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtHelp4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtHelpd4.a
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtHelpd4.a
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtHelp4.a
//The Qt QTMAIN library
QT_QTMAIN_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libqtmain.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libqtmaind.a
QT_QTMAIN_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libqtmaind.a
QT_QTMAIN_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libqtmain.a
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtNetwork4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtNetworkd4.a
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtNetworkd4.a
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtNetwork4.a
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGL4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGLd4.a
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGLd4.a
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGL4.a
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtScript4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtScriptd4.a
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtScriptd4.a
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtScript4.a
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtSql4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtSqld4.a
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtSqld4.a
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtSql4.a
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtSvg4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtSvgd4.a
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtSvgd4.a
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtSvg4.a
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtTest4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtTestd4.a
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtTestd4.a
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtTest4.a
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtUiTools.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtUiToolsd.a
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtUiToolsd.a
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtUiTools.a
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtWebKit4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtWebKitd4.a
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtWebKitd4.a
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtWebKit4.a
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtXmlPatterns4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtXmlPatternsd4.a
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtXmlPatternsd4.a
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtXmlPatterns4.a
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:FILEPATH=optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtXml4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtXmld4.a
QT_QTXML_LIBRARY_DEBUG:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtXmld4.a
QT_QTXML_LIBRARY_RELEASE:FILEPATH=C:/devel/Qt/4.6.0-beta1/lib/libQtXml4.a
//Path to a file.
QT_QT_INCLUDE_DIR:PATH=C:/devel/Qt/4.6.0-beta1/include/Qt
QT_RCC_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/rcc.exe
QT_UIC3_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/uic3.exe
//The uic executable
QT_UIC_EXECUTABLE:FILEPATH=C:/devel/Qt/4.6.0-beta1/bin/uic.exe
//Enable CGAL component ImageIO
WITH_CGAL_ImageIO:BOOL=ON
//Enable CGAL component PDB
WITH_CGAL_PDB:BOOL=ON
//Enable CGAL component Qt3
WITH_CGAL_Qt3:BOOL=OFF
//Enable CGAL component Qt4
WITH_CGAL_Qt4:BOOL=ON
//Create package generation rules
WITH_CPACK:BOOL=OFF
//Use the GMP number types if available.
WITH_GMP:BOOL=OFF
//Use the LEDA number types if available.
WITH_LEDA:BOOL=OFF
//Select demos
WITH_demos:BOOL=OFF
//Select examples
WITH_examples:BOOL=OFF
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=ZLIB_INCLUDE_DIR-NOTFOUND
ZLIB_LIBRARY:FILEPATH=ZLIB_LIBRARY-NOTFOUND
# INTERNAL cache entries
//Name of all CGAL libraries.
ALL_CGAL_LIBRARIES:INTERNAL=CGAL;CGAL_Core;CGAL_ImageIO;CGAL_PDB;CGAL_Qt3;CGAL_Qt4
//Advanced flag for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//The library version string for boost libraries
Boost_LIB_VERSION:INTERNAL=1_40
//Advanced flag for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//The version number for boost libraries
Boost_VERSION:INTERNAL=104000
CGAL_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/devel/tools/boost_1_40_0
CGAL_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_CFG_DENORMALS_COMPILE_BUG:INTERNAL=0
//Result of TRY_COMPILE
CGAL_CFG_DENORMALS_COMPILE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG:INTERNAL=0
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_IEEE_754_BUG:INTERNAL=0
CGAL_CFG_IEEE_754_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_ISTREAM_INT_BUG:INTERNAL=0
CGAL_CFG_ISTREAM_INT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_LONGNAME_BUG:INTERNAL=0
CGAL_CFG_LONGNAME_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_5:INTERNAL=0
CGAL_CFG_MATCHING_BUG_5_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_6:INTERNAL=0
CGAL_CFG_MATCHING_BUG_6_COMPILED:INTERNAL=TRUE
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG:INTERNAL=0
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NET2003_MATCHING_BUG:INTERNAL=0
CGAL_CFG_NET2003_MATCHING_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_ARRAY:INTERNAL=1
CGAL_CFG_NO_CPP0X_ARRAY_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DECLTYPE:INTERNAL=1
CGAL_CFG_NO_CPP0X_DECLTYPE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS:INTERNAL=0
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_ISFINITE:INTERNAL=0
CGAL_CFG_NO_CPP0X_ISFINITE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_LONG_LONG:INTERNAL=0
CGAL_CFG_NO_CPP0X_LONG_LONG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE:INTERNAL=1
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_TUPLE:INTERNAL=1
CGAL_CFG_NO_CPP0X_TUPLE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_LIMITS:INTERNAL=0
CGAL_CFG_NO_LIMITS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_NEXTAFTER:INTERNAL=0
CGAL_CFG_NO_NEXTAFTER_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_STATEMENT_EXPRESSIONS:INTERNAL=0
CGAL_CFG_NO_STATEMENT_EXPRESSIONS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_STL:INTERNAL=0
CGAL_CFG_NO_STL_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM:INTERNAL=0
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TR1_ARRAY:INTERNAL=0
CGAL_CFG_NO_TR1_ARRAY_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TR1_TUPLE:INTERNAL=0
CGAL_CFG_NO_TR1_TUPLE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NUMERIC_LIMITS_BUG:INTERNAL=0
CGAL_CFG_NUMERIC_LIMITS_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG:INTERNAL=0
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG:INTERNAL=0
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_USING_BASE_MEMBER_BUG_2:INTERNAL=0
CGAL_CFG_USING_BASE_MEMBER_BUG_2_COMPILED:INTERNAL=TRUE
CGAL_Core_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Core_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Variable hidden from user
CGAL_Core_LIBRARY_NAME:INTERNAL=
CGAL_EXECUTABLE_TARGETS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_LIBRARIES:INTERNAL=glu32;opengl32
CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Advanced flag for variable: CGAL_ImageIO_LIBRARY
CGAL_ImageIO_LIBRARY-ADVANCED:INTERNAL=1
CGAL_ImageIO_LIBRARY_NAME:INTERNAL=libCGAL_ImageIO.a
CGAL_LIBRARY:INTERNAL=C:/devel/tools/CGAL-3.5/lib/libCGAL.a
CGAL_LIBRARY_NAME:INTERNAL=libCGAL.a
CGAL_PDB_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_PDB_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_PDB_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_PDB_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Advanced flag for variable: CGAL_PDB_LIBRARY
CGAL_PDB_LIBRARY-ADVANCED:INTERNAL=1
CGAL_PDB_LIBRARY_NAME:INTERNAL=libCGAL_PDB.a
CGAL_Qt3_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt3_LIBRARY_NAME:INTERNAL=
CGAL_Qt4_3RD_PARTY_DEFINITIONS:INTERNAL=-DQT_DLL
CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/devel/Qt/4.6.0-beta1/include
CGAL_Qt4_3RD_PARTY_LIBRARIES:INTERNAL=optimized;C:/devel/Qt/4.6.0-beta1/lib/libqtmain.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libqtmaind.a;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGL4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtOpenGLd4.a;-lopengl32
-lglu32 -lgdi32
-luser32;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtGui4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtGuid4.a;imm32;winmm;optimized;C:/devel/Qt/4.6.0-beta1/lib/libQtCore4.a;debug;C:/devel/Qt/4.6.0-beta1/lib/libQtCored4.a;ws2_32;glu32;opengl32
CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Advanced flag for variable: CGAL_Qt4_LIBRARY
CGAL_Qt4_LIBRARY-ADVANCED:INTERNAL=1
CGAL_Qt4_LIBRARY_NAME:INTERNAL=libCGAL_Qt4.a
//Advanced flag for variable: CGAL_SONAME_VERSION
CGAL_SONAME_VERSION-ADVANCED:INTERNAL=1
//Advanced flag for variable: CGAL_SOVERSION
CGAL_SOVERSION-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_AR
CMAKE_AR-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_BACKWARDS_COMPATIBILITY
CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=C:/devel/MinGW/bin/mingw32-make.exe
//This is the directory where this CMakeCahe.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/devel/tools/CGAL-3.5
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=6
CMAKE_CACHE_RELEASE_VERSION:INTERNAL=patch 4
//Advanced flag for variable: CMAKE_COLOR_MAKEFILE
CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.6/bin/cmake.exe
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.6/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.6/bin/ctest.exe
//Advanced flag for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.6/bin/cmake-gui.exe
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=Unknown
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=MinGW Makefiles
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/devel/tools/CGAL-3.5
//Advanced flag for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_NM
CMAKE_NM-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=6
//Advanced flag for variable: CMAKE_OBJCOPY
CMAKE_OBJCOPY-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_OBJDUMP
CMAKE_OBJDUMP-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_RANLIB
CMAKE_RANLIB-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files (x86)/CMake 2.6/share/cmake-2.6
//Advanced flag for variable: CMAKE_SH
CMAKE_SH-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_STRIP
CMAKE_STRIP-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
CMAKE_UNAME:INTERNAL=CMAKE_UNAME-NOTFOUND
//Advanced flag for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
EXECUTABLE_OUTPUT_PATH:INTERNAL=
GCC_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
GCC_RUN_RES:INTERNAL=0
GMP_IN_CGAL_AUXILIARY:INTERNAL=TRUE
LIBRARY_OUTPUT_PATH:INTERNAL=C:/devel/tools/CGAL-3.5/lib
MPFR_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Advanced flag for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_INCLUDE_DIR
QT3_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_MOC_EXECUTABLE
QT3_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QASSISTANTCLIENT_LIBRARY
QT3_QASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QTMAIN_LIBRARY
QT3_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QT_LIBRARY
QT3_QT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_UIC_EXECUTABLE
QT3_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
QT4_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
QT4_RUN_RES:INTERNAL=0
QT_BINARY_DIR:INTERNAL=C:/devel/Qt/4.6.0-beta1/bin
//Advanced flag for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=C:/devel/Qt/4.6.0-beta1/include
//Advanced flag for variable: QT_INCLUDE_DIR
QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY
QT_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY_DEBUG
QT_QTMAIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY_RELEASE
QT_QTMAIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT_INCLUDE_DIR
QT_QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=1
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//Advanced flag for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
- [cgal-discuss] Installation of CGAL 3.5, dimanne, 11/10/2009
- Re: [cgal-discuss] Installation of CGAL 3.5, Laurent Rineau (GeometryFactory), 11/10/2009
- Re: [cgal-discuss] Installation of CGAL 3.5, Dimanne, 11/10/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Installation of CGAL 3.5, Dimanne, 11/11/2009
