[cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question
- To:
- Subject: [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question
- Date: Thu, 12 Nov 2009 00:59:33 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=RWHWrHh3ZrflwTDHsv86nbdR+TfEXfoldOehioXX5T/50Rvt5hgygqNhpLdhawCu0C szTizSD994osQuxr85c9y5S59mnegSolLaiCVn9Fs7cPQz7CPjd8BsFssvoDiAPnJcvC OEKZWLc5Yf2WumqSX0vTsWorCEP99m0eHRf2o=
Hello everyone,
After I perform some operations on the Delaunay data structure, I want to remove certain vertices from it and then continue with the processing. To avoid removing the same vertex more than once, I compare the points, i.e.
std::set<Vertex_handle> toRemove;
std::set<Point> seen;
for(std::list<Facet>::iterator iter = grown->facets->begin();
iter != grown->facets->end(); ++iter) {
Cell_handle c = (*iter).first;
int index = (*iter).second;
Point p1 = c->vertex((index+1)%4)->point();
Point p2 = c->vertex((index+2)%4)->point();
Point p3 = c->vertex((index+3)%4)->point();
// Do not remove points already removed from a neighboring cell
if(seen.insert(p1).second) {
toRemove.insert(c->vertex((index+1)%4));
if(seen.insert(p2).second) {
toRemove.insert(c->vertex((index+2)%4));
if(seen.insert(p3).second) {
toRemove.insert(c->vertex((index+3)%4));
T.remove(toRemove.begin(), toRemove.end());
However, I get the same error as before (but is_valid() returns true :/):
CGAL error: assertion violation!
Expr: v == V[3]
File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Then, I wanted to reconstruct the whole triangulation from scratch after every cycle of the algorithm (not practical, but in desperate times need desperate measures), and then this part causes trouble
if(T.is_infinite(*iter)) {
continue;
Triangle triangle = T.triangle(*iter);
if(triangle.is_degenerate() || TrigPerimeter(triangle) < 0.1) {
continue;
Point circumcenter = CGAL::circumcenter(triangle);
The call to the circumcenter functions fails, and I suppose that this is because I'm using an inexact_constructions kernel. Is there any trick around this, i.e. some condition/heuristic that will skip these triangles? Changing the kernel itself is of course a possibility, however it will introduce a lot of changes in the whole project (because it is assumed in most of the code that some CGAL functions return something castable to double).
Thank you very much,
Josip
- [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question, Josip Dzolonga, 11/12/2009
- Re: [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question, Manuel Caroli, 11/12/2009
- Re: [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question, Josip Dzolonga, 11/13/2009
