cgal-discuss - Re: [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question
  • To:
  • Subject: Re: [cgal-discuss] Problems with using the Delaunay 3 data structure + some robustness question
  • Date: Thu, 12 Nov 2009 09:46:53 +0100
Hi Josip,
Josip Dzolonga wrote:
Hello everyone,
After I perform some operations on the Delaunay data structure, I want to remove certain vertices from it and then continue with the processing. To avoid removing the same vertex more than once, I compare the points, i.e.
The problem is caused by a call to the function index(Vertex_handle v) in a cell that does not contain v as a vertex. From the code snipped you provide below it is not clear where the problem comes from. Could you please provide a minimal example that can be compiled and that shows the problem.
By the way, I don't understand why you need the set seen but anyway this should not cause the problem.
std::set<Vertex_handle> toRemove;
std::set<Point> seen;
for(std::list<Facet>::iterator iter = grown->facets->begin();
iter != grown->facets->end(); ++iter) {
Cell_handle c = (*iter).first;
int index = (*iter).second;
Point p1 = c->vertex((index+1)%4)->point();
Point p2 = c->vertex((index+2)%4)->point();
Point p3 = c->vertex((index+3)%4)->point();
// Do not remove points already removed from a neighboring cell
if(seen.insert(p1).second) {
toRemove.insert(c->vertex((index+1)%4));
if(seen.insert(p2).second) {
toRemove.insert(c->vertex((index+2)%4));
if(seen.insert(p3).second) {
toRemove.insert(c->vertex((index+3)%4));
T.remove(toRemove.begin(), toRemove.end());
However, I get the same error as before (but is_valid() returns true :/):
CGAL error: assertion violation!
Expr: v == V[3]
File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Then, I wanted to reconstruct the whole triangulation from scratch after every cycle of the algorithm (not practical, but in desperate times need desperate measures), and then this part causes trouble
if(T.is_infinite(*iter)) { continue; } Triangle triangle = T.triangle(*iter); if(triangle.is_degenerate() || TrigPerimeter(triangle) < 0.1) { continue; } Point circumcenter = CGAL::circumcenter(triangle);
What exactly does it mean that the call to circumcenter "fails"? The only issue I see right now would be that the triangle is very flat. Then you might get a division by 0 or an overflow because the circumcenter is very far away...
Could you check how the triangle looks like, for which circumcenter fails ?
best
Manuel
The call to the circumcenter functions fails, and I suppose that this is because I'm using an inexact_constructions kernel. Is there any trick around this, i.e. some condition/heuristic that will skip these triangles? Changing the kernel itself is of course a possibility, however it will introduce a lot of changes in the whole project (because it is assumed in most of the code that some CGAL functions return something castable to double).
Thank you very much,
Josip
