- To:
- Subject: Re: [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!
- Date: Sat, 14 Nov 2009 16:13:43 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=vjCuHF/2eo2l+Cv3Wsfcu0TLxS21Dy7Sct4c3OxBh8UQVdyU2BZCSLTHXjYnnRWF6j GlNzqjzxmu8vQ/gUC81gANGSZlq9fAocQou6uXkt6kl+xgQ6gadrFvP7TpO2igBuRX4d koVBmhiENC4+8pA4nqfTOEn+Kr5o+J/gpBS/s=
...I have to tell you (it might be important) that I use the methode inside a class that inheritate from Polygon_2 !
Gilles
2009/11/14 Gilles <>
Hello all,
I'm pretty new in CGAL (as well as in C++), it might be a silly question !
I really need help !!!
THE ERROR IS :
erreur: conversion from
«std::_List_iterator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >» to non-scalar type
«__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
std::vector<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
std::allocator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > > > >» requested
THE CODE IS :
Polygon_2 polygon;
Polygon_list partition_polys;
CGAL::random_polygon_2(50, std::back_inserter(polygon),
Point_generator(100));
CGAL::approx_convex_partition_2(polygon.vertices_begin(),
polygon.vertices_end(),
std::back_inserter(partition_polys));
// transverse the polygon-list
for (Polygon_iterator poly_it = partition_polys.begin(); poly_it !=
partition_polys.end();poly_it++)
// HERE IS THE ERROR
for (Vertex_iterator it=(*poly_it).vertices_begin();it !=
(*poly_it).vertices_end();++it)
HERE IS THE INCLUDE / TYPE-DEF I USE :
#include <CGAL/basic.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_traits_2.h>
#include <CGAL/intersections.h>
#include <CGAL/Partition_traits_2.h>
#include <CGAL/partition_2.h>
#include <CGAL/point_generators_2.h>
#include <CGAL/random_polygon_2.h>
#include <cassert>
#include <list>
#include "../AC_Forme3D/ac_forme3d.h"
#include "../AC_Utilities/ac_utilities.h"
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point;
typedef K::Segment_2 Segment_2;
typedef CGAL::Polygon_traits_2<K> Gp;
typedef CGAL::Polygon_2<Gp>::Vertex_iterator vertexIterator;
typedef CGAL::Partition_traits_2<K> Traits;
typedef Traits::Point_2 Point_2;
typedef Traits::Polygon_2 Polygon_2;
typedef Polygon_2::Vertex_iterator Vertex_iterator;
typedef std::list<Polygon_2> Polygon_list;
typedef CGAL::Creator_uniform_2<int, Point_2> Creator;
typedef CGAL::Random_points_in_square_2<Point_2, Creator> Point_generator;
typedef std::list<Polygon_2>::const_iterator Polygon_iterator;
Thanks in advance !
Gilles
- [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!, Gilles, 11/14/2009
- Re: [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!, Gilles Kneuss, 11/14/2009
- Re: [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!, Gilles Kneuss, 11/15/2009
