cgal-discuss - Re: [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!
  • To:
  • Subject: Re: [cgal-discuss] Cannot traverse vertices of Polygon_2 H E L P !!!
  • Date: Sun, 15 Nov 2009 16:01:50 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=n1nB/m8F7XqkbY6aSxwf19cnB51Ji76p0U67zBZVjGQ/TOe6ruAJERL4hIzjR2YXVQ gYCy/3gGg1YIu3/nmZsb31wbI/KJVYZM0ULzvyVSIzAtFVvUE6yZI1ifgycM7ROFHNfI coneyZByyL8hQpATjUoN/6sXpTIaoGT5REn04=
Hello all,
I finally found my error :
-> Partition has need specific type in input / in output and I did not care
about it !
Gilles
2009/11/14 Gilles Kneuss <>
...I have to tell you (it might be important) that I use the methode inside a class that inheritate from Polygon_2 !
Gilles
2009/11/14 Gilles <>
Hello all,
I'm pretty new in CGAL (as well as in C++), it might be a silly question !
I really need help !!!
THE ERROR IS :
erreur: conversion from
«std::_List_iterator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >» to non-scalar type
«__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
std::vector<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
std::allocator<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > > > >» requested
THE CODE IS :
  Polygon_2    polygon;
  Polygon_list partition_polys;
  CGAL::random_polygon_2(50, std::back_inserter(polygon),
                         Point_generator(100));
  CGAL::approx_convex_partition_2(polygon.vertices_begin(),
                                  polygon.vertices_end(),
                                  std::back_inserter(partition_polys));
 // transverse the polygon-list
 for (Polygon_iterator poly_it = partition_polys.begin(); poly_it !=
partition_polys.end();poly_it++)
     // HERE IS THE ERROR
     for (Vertex_iterator it=(*poly_it).vertices_begin();it !=
(*poly_it).vertices_end();++it)
HERE IS THE INCLUDE / TYPE-DEF I USE :
#include <CGAL/basic.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_traits_2.h>
#include <CGAL/intersections.h>
#include <CGAL/Partition_traits_2.h>
#include <CGAL/partition_2.h>
#include <CGAL/point_generators_2.h>
#include <CGAL/random_polygon_2.h>
#include <cassert>
#include <list>
#include "../AC_Forme3D/ac_forme3d.h"
#include "../AC_Utilities/ac_utilities.h"
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point;
typedef K::Segment_2 Segment_2;
typedef CGAL::Polygon_traits_2<K> Gp;
typedef CGAL::Polygon_2<Gp>::Vertex_iterator vertexIterator;
typedef CGAL::Partition_traits_2<K>                         Traits;
typedef Traits::Point_2                                     Point_2;
typedef Traits::Polygon_2                                   Polygon_2;
typedef Polygon_2::Vertex_iterator                          Vertex_iterator;
typedef std::list<Polygon_2>                                Polygon_list;
typedef CGAL::Creator_uniform_2<int, Point_2>               Creator;
typedef CGAL::Random_points_in_square_2<Point_2, Creator>   Point_generator;
typedef  std::list<Polygon_2>::const_iterator   Polygon_iterator;
Thanks in advance !
Gilles
