Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
- To:
- Subject: Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
- Date: Thu, 19 Nov 2009 14:10:58 +0100
The error message is related to lapack library.
Actually there is already a Lapack in the developer tools furnished by apple.
The thing is that you probably are not pointing to it so try to activate accelerate_framework variable in cmake configure or check DYLIB_PATH or LD_LIBRARY_PATH I am not sure which one is more appropriate.
Actually I have also installed CGAL and it do recognize lapack so good luck.
Nizar SALLEM
Robotics and Artificial Intelligence PhD student
LAAS-CNRS
7, Avenue Colonel Roche
31077 Toulouse CEDEX 4
FRANCE
On Nov 19, 2009, at 12:58 PM, <> < > wrote:
Hi,
I am new to CGAL, so please bear with me if this is very elementary, but here
is my problem:
I want to use the Surface Reconstruction from Point Sets package which depends
on TAUCS.
I have successfully built TAUCS for 64-bit using libmetis and libf2c which are
also built for 64-bit Intel.
I am using cmake-gui to define the following cmake variables:
METIS_LIBRARY
TAUCS_LIBRARY
TAUCS_INCLUDE_DIR
TAUCS_LIBRARIES_DIR
libCGAL.4.0.0.dylib builds without any problems.
However, when I try to link against my GCAL lib, I get CGAL::LAPACK::dgelss
cannot be found error from the linker.
Which LAPACK implementation do I need to link CGAL against? I though TAUCS was
already providing the LAPACK methods.
Thanks in advance for your help.
Cheers,
Engin Kurutepe.
- [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, kurutepe, 11/19/2009
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Nizar Khalifa Sallem, 11/19/2009
- Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs, Engin Kurutepe, 11/19/2009
