cgal-discuss - Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
  • To:
  • Subject: Re: [cgal-discuss] dgelss cannot be found CGAL3.5 OSX10.6.2 gcc4.2.1 cmake2.6 taucs
  • Date: Thu, 19 Nov 2009 14:31:40 +0100
Thanks a lot, Nizar. That solved my problem.
Cheers,
Engin.
Engin Kurutepe TU Berlin
FG Nachrichtenübertragung
Tel: +49 30 314 28507 Sekr. EN-1, Einsteinufer 17
Fax: +49 30 314 22514 10587 Berlin Germany
On 19. Nov 09, at 14:10 , Nizar Khalifa Sallem wrote:
> The error message is related to lapack library.
> Actually there is already a Lapack in the developer tools furnished by
> apple.
> The thing is that you probably are not pointing to it so try to activate
> accelerate_framework variable in cmake configure or check DYLIB_PATH or
> LD_LIBRARY_PATH I am not sure which one is more appropriate.
> Actually I have also installed CGAL and it do recognize lapack so good luck.
> Nizar SALLEM
> Robotics and Artificial Intelligence PhD student
> LAAS-CNRS
> 7, Avenue Colonel Roche
> 31077 Toulouse CEDEX 4
> FRANCE
> On Nov 19, 2009, at 12:58 PM,
> wrote:
>> Hi,
>> I am new to CGAL, so please bear with me if this is very elementary, but
>> here
>> is my problem:
>> I want to use the Surface Reconstruction from Point Sets package which
>> depends
>> on TAUCS.
>> I have successfully built TAUCS for 64-bit using libmetis and libf2c which
>> are
>> also built for 64-bit Intel.
>> I am using cmake-gui to define the following cmake variables:
>> METIS_LIBRARY
>> TAUCS_LIBRARY
>> TAUCS_INCLUDE_DIR
>> TAUCS_LIBRARIES_DIR
>> libCGAL.4.0.0.dylib builds without any problems.
>> However, when I try to link against my GCAL lib, I get CGAL::LAPACK::dgelss
>> cannot be found error from the linker.
>> Which LAPACK implementation do I need to link CGAL against? I though TAUCS
>> was
>> already providing the LAPACK methods.
>> Thanks in advance for your help.
>> Cheers,
>> Engin Kurutepe.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
