Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets
- To:
- Subject: Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets
- Date: Fri, 20 Nov 2009 09:27:05 +0100
No, there isn't. CGAL surface reconstruction from point sets is
currently limited to smooth surfaces. Best regards, Laurent Saboret schwoe wrote: Thanks for your answer! I already tried the surface reconstruction from point set, but it doesn't work for sharp creases and a low number of points. Or is there maybe an option to get it to work with cuboid-like bodies? Best regards, Christian Flaminigo wrote:Hi, I remember there are surface reconstruction function from the point set data in CGAL. It can handle more complex model than your models. You can have a try. |
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in
any contract or obligation, nor its subsidiaries.
- [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets, schwoe, 11/18/2009
- Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets, Flaminigo, 11/19/2009
- Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets, schwoe, 11/19/2009
- Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets, Laurent Saboret, 11/20/2009
- Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets, Nizar Khalifa Sallem, 11/19/2009
