cgal-discuss - Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets
  • To:
  • Subject: Re: [cgal-discuss] Surface Meshing for simple geometric bodies represented through point sets
  • Date: Thu, 19 Nov 2009 10:11:22 -0800 (PST)
Thanks for your answer!
I already tried the surface reconstruction from point set, but it doesn't
work for sharp creases and a low number of points. Or is there maybe an
option to get it to work with cuboid-like bodies?
Best regards,
Christian
Flaminigo wrote:
> Hi,
> I remember there are surface reconstruction function from the point set
> data in CGAL. It can handle more complex model than your models. You can
> have a try.
View this message in context:
http://old.nabble.com/Surface-Meshing-for-simple-geometric-bodies-represented-through-point-sets-tp26390431p26421422.html
