cgal-discuss - Re: [cgal-discuss] "Parts" of Polyhedron after a boolean operations.
  • To:
  • Subject: Re: [cgal-discuss] "Parts" of Polyhedron after a boolean operations.
  • Date: Tue, 01 Dec 2009 17:12:57 -0800
  • Organization: INRIA
hi Gilles,
did you already apply the conversion from the nef polyhedron to the surface polyhedron?
then to do the split I would recommend using the incremental builder in order to do the split into several polyhedra. let me know if you want some example code to use as starting point for this task.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Gilles a écrit :
Hello all,
When I make a boolean op. on 3D Polyhedron and the result is completely parted
(for exemple, I cutted a cylinder into two distinct parts),
I would like to identify these two parts (to make two new Polyhedron
afterwards).
Anyone has an answer how can I proceed ?
Thanks for help.
