cgal-discuss - Re: [cgal-discuss] "Parts" of Polyhedron after a boolean operations.
  • To:
  • Subject: Re: [cgal-discuss] "Parts" of Polyhedron after a boolean operations.
  • Date: Wed, 02 Dec 2009 20:11:28 -0800
  • Organization: INRIA
Gilles wote:
> Yes, if you have an examples (using incrémental builder) it would be wonderful !
hi Gilles,
less trivial than I thought but doable - here is the code (.h file attached that makes it) - see usage below.
(we may want to add this to the polyhedron demo - a menu "explode" which generates as many meshes as connected components)
let me know if you can improve this code, ok?
pierre
#include "explode.h"
  std::list<Polyhedron> polyhedra;
  typedef std::back_insert_iterator<std::list<Polyhedron> > OutputIterator;
  Explode_polyhedron<Polyhedron,Kernel,OutputIterator> Explode;
  std::cout << "explode polyhedron...";
  Explode.run(polyhedron,std::back_inserter(polyhedra));
  std::cout << "done (" << polyhedra.size() << " components)" << std::endl;
  // save meshes to off files
  int index = 1;
  std::list<Polyhedron>::iterator it;
  for(it = polyhedra.begin();
      it != polyhedra.end();
      it++, index++)
    char pFilename[256];
    sprintf(pFilename,"mesh%d.off",index);
    std::ofstream stream(pFilename);
    stream << *it;
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Gilles Kneuss a écrit :
hi Pierre,
Thanks.
Gilles
2009/12/2 Pierre Alliez <>
hi Gilles,
did you already apply the conversion from the nef polyhedron to the surface polyhedron?
then to do the split I would recommend using the incremental  builder in order to do the split into several polyhedra. let me know if you want some example code to use as starting point for this task.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Gilles a écrit :
Hello all,
When I make a boolean op. on 3D Polyhedron and the result is completely parted
(for exemple, I cutted a cylinder into two distinct  parts),
 I would like to identify these two parts (to make two new Polyhedron
afterwards).
Anyone has an answer how can I proceed ?
Thanks for help.
#ifndef _EXPLODE_
#define _EXPLODE_
#include <set>
#include <map>
#include <stack>
#include <CGAL/Modifier_base.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
template<class Handle>
struct less_handle
bool operator()(const Handle& h1,
const Handle& h2) const
return &(*h1) < &(*h2);
template <class HDS, class Polyhedron, class Kernel>
class CModifierExplode : public CGAL::Modifier_base<HDS>
private:
typedef typename Kernel::Triangle_3 Triangle;
typedef typename HDS::Face_handle Face_handle;
typedef typename HDS::Vertex_handle Vertex_handle;
typedef typename HDS::Halfedge_handle Halfedge_handle;
typedef typename Polyhedron::Halfedge_around_facet_circulator F_circulator;
typedef typename CGAL::Polyhedron_incremental_builder_3<HDS> builder;
typedef typename std::set<Face_handle, less_handle<Face_handle> > Faces;
typedef typename std::set<Vertex_handle, less_handle<Vertex_handle> >
Vertices;
typedef typename std::set<Halfedge_handle, less_handle<Halfedge_handle> >
Halfedges;
Halfedges& m_halfedges;
Halfedge_handle m_seed_halfedge;
public:
// life cycle
CModifierExplode(Halfedge_handle seed_halfedge,
Halfedges& halfedges)
: m_seed_halfedge(seed_halfedge),
m_halfedges(halfedges)
~CModifierExplode() {}
// make one connected component
void operator()( HDS& hds)
Faces faces;
Vertices vertices;
std::list<Vertex_handle> ordered_vertices;
std::map<Vertex_handle,int,less_handle<Vertex_handle> > vertex_map;
// traverse component and fill sets
std::stack<Halfedge_handle> stack;
stack.push(m_seed_halfedge);
int vertex_index = 0;
while(!stack.empty())
// pop halfedge from queue
Halfedge_handle he = stack.top();
stack.pop();
m_halfedges.insert(he);
// let's see its incident face
if(!he->is_border())
Face_handle f = he->facet();
if(faces.find(f) == faces.end())
faces.insert(f);
// let's see its end vertex
Vertex_handle v = he->vertex();
if(vertices.find(v) == vertices.end())
vertices.insert(v);
ordered_vertices.push_back(v);
vertex_map[v] = vertex_index++;
// go and discover component
Halfedge_handle nhe = he->next();
Halfedge_handle ohe = he->opposite();
if(m_halfedges.find(nhe) == m_halfedges.end())
stack.push(nhe);
if(m_halfedges.find(ohe) == m_halfedges.end())
stack.push(ohe);
builder B(hds,true);
B.begin_surface(3,1,6);
// add vertices
std::list<Vertex_handle>::iterator vit;
for(vit = ordered_vertices.begin();
vit != ordered_vertices.end();
vit++)
Vertex_handle v = *vit;
B.add_vertex(v->point());
// add facets
Faces::iterator fit;
for(fit = faces.begin();
fit != faces.end();
fit++)
Face_handle f = *fit;
B.begin_facet();
F_circulator he = f->facet_begin();
F_circulator end = he;
CGAL_For_all(he,end)
B.add_vertex_to_facet(vertex_map[v]);
B.end_facet();
B.end_surface();
template <class Polyhedron,
class Kernel,
class OutputIterator>
class Explode_polyhedron
public:
typedef typename Polyhedron::HalfedgeDS HalfedgeDS;
typedef typename Polyhedron::Halfedge_handle Halfedge_handle;
typedef typename Polyhedron::Halfedge_iterator Halfedge_iterator;
public:
Explode_polyhedron() {}
~Explode_polyhedron() {}
public:
void run(Polyhedron &polyhedron,
OutputIterator out)
std::set<Halfedge_handle,less_handle<Halfedge_handle> > halfedges;
Polyhedron::Halfedge_iterator he;
for(he = polyhedron.halfedges_begin();
he != polyhedron.halfedges_end();
he++)
if(halfedges.find(he) == halfedges.end())
// adds one component as polyhedron
CModifierExplode<HalfedgeDS,Polyhedron,Kernel> modifier(he,halfedges);
Polyhedron component;
component.delegate(modifier);
*out = component;
out++;
#endif // _EXPLODE_
