- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation
- Date: Wed, 2 Dec 2009 13:14:16 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Abr2czNSKv6XNx+qTQsCPRPMZpGJPnm39KMVK5DV1EaPszriwiKylbZHnJet51hl8l Gwp771QNvRLWmFvzQgLFjh9AoNwUJZskO7kA2dIkgeVDR4u3xhS5k6+FCbTf/Kt4O2KR pjAzXTvCPjkY1b9f54NjcVNdPTJm46iicyaVQ=
Interesting....
I added the following to the autogenerated CMakeLists.txt file
# Created by the script cgal_create_cmake_script
# This is the CMake script for compiling a CGAL application.
project( meshing-work_test )
CMAKE_MINIMUM_REQUIRED(VERSION 2.4.5)
# ADDED FOR DEBUG
set(CMAKE_BUILD_TYPE Debug)
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
I recompiled and the code worked. So I suspect that it is the compiler bug. Thanks for the help.
Steve
On Wed, Dec 2, 2009 at 12:45 PM, Sylvain Pion <> wrote:
It's probable that you are a victim of the gcc bug mentioned in the FAQ.
Try to use a more recent compiler, or remove optimization (tell cmake
to use the debug mode instead of the default which is the release).
Stephen Sintay a écrit :
Ahh. SorryOn Wed, Dec 2, 2009 at 12:12 PM, Sylvain Pion < <mailto:>> wrote:
$ ./mesh_implicit_sphere
Got here
Got here
Got here
Bus error
$ g++ -v
Using built-in specs.
Target: i686-apple-darwin9
Configured with: /var/tmp/gcc/gcc-5488~2/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=i686-apple-darwin9 --with-arch=apple --with-tune=generic --host=i686-apple-darwin9 --target=i686-apple-darwin9
Thread model: posix
gcc version 4.0.1 (Apple Inc. build 5488)
<mailto:> a écrit :
On execution the example fails at the line (47):
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
Describe "fails", please.
Also, which compiler version are you using ?
I'm thinking it can be related to
http://www.cgal.org/FAQ.html#mac_optimization_bug
-- Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
-- You are currently subscribed to cgal-discuss.
Sylvain Pion
- [cgal-discuss] 3D Mesh Generation, stephen.sintay, 12/02/2009
- Re: [cgal-discuss] 3D Mesh Generation, Sylvain Pion, 12/02/2009
- Re: [cgal-discuss] 3D Mesh Generation, Stephen Sintay, 12/02/2009
