cgal-discuss - [cgal-discuss] A geometry question
  • To:
  • Subject: [cgal-discuss] A geometry question
  • Date: Wed, 2 Dec 2009 16:16:35 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=u7MaZVzHFQE4BWhatOGnhlOiaDW5rRGOhHbUsbYU51ylHlcoBkO4iLkq1NOpZ6JOog Z3YID7JUDbB2cOQdOxsTpYGU3ag/NaHmMyu/wQDDNnbP5YpV2a9NCqqI11U6T2ie8Ldy +pj9p2JWRF9U1sYNvCjSLsUZb7tXUsOPGUm4I=
Hi everyone,
I have a general geometry question as follows.
A polyhedron (non-convex with triangles as its bounding facets) is
given. For a given facet determine the maximum sized sphere that is
tangential to the facet and contained completely inside the
polyhedron.
I am trying to approach it as an optimization problem. My approach is
as follows.
1. Express the point where the sphere touches the triangular facet in
terms of barycentric coordinates
P_touch = alpha*X_1 + beta*X_2 + gamma*X_3
alpha, beta, gamma are unknown. X_1, X_2, X_3 are vertices of queried
facet and known.
2. The center of sphere must lie on the normal of triangular facet
passing through the P_touch.
Express center of sphere as:
P_center = P_touch + normal*R
where, normal is normal vector and known, R is radius of sphere and unknown.
3. Solve following optimization problem:
Maximize R
S.T.
nR^2 - Sum[(x_j - P_center) dot(x_j - P_center) ] >= 0 (as all points
x_j lying on the polyhedron surface lie outside or on the sphere)
0<alpha, beta, gamma<1
R>0
Problem with 4 variables(alpha, beta, gamma, R) and 8 constraints.
I guess solving above optimization problem can give me the answer but
is there a smart way to solve this problem that I am missing using
some existing geometric constructs like Voronoi cells. Any pointers
would be really helpful.
thanks,
-Atul
