cgal-discuss - Re: [cgal-discuss] AABBTree primitives or objects problem
  • To: "" <>
  • Subject: Re: [cgal-discuss] AABBTree primitives or objects problem
  • Date: Thu, 3 Dec 2009 17:21:08 +0100
the tree.number_of_intersected_primitives(Segment) gives me 5
intersections. But if I use the code to test what type of objects are. only 3
are Point_3. What are the other 2?
Hi Roberto,
This is a typical robustness issue: I guess you use the exact_predicates_inexact_constructions kernel. In such a case, the do_intersect predicate used to answer the number_of_intersections query is exact. Hence the answer 5. On the other hand, the intersection constructions are not, and I suspect that they simply do not find any intersection for the two missing cases (I assume from your message that the code did not find any segment intersection).
Of course, it would be better if the predicates and the constructions were consistent in the exact_predicates_inexact_constructions kernel (i.e. Always returning a non empty construction if the predicate said so). This is on some todo-list, but it is a delicate question. (note that it is not really AABB-tree related)
Best
Camille
