- To: "" <>
- Subject: Re: [cgal-discuss] AABBTree primitives or objects problem
- Date: Fri, 4 Dec 2009 11:48:39 +0100
Hi Roberto,
There is a method all_intersected_primitives which allows to retrieve the primitives for which the do_intersect predicate returned true. It will give you the 5 of them.
Does it answer your question?
Camille
On Dec 4, 2009, at 11:34, Roberto Lam
wrote:
Hi Camile,
thanks for the quick answer. You are right I am using
and indeed isn't a AABBTree problem. There is any way to access
information from the primitives? Where can I get more information
them? In the code (below) I saw in VS debugger that 'op' has a
'second' field. So far I discover from the debugger that has
information on facet (I am using a polyhedron_3 as base for
constructing my AABBTree) but I dont know what is or how to use it.
thanks for the help
roberto
for ( it=intersections.begin() ; it != intersections.end(); it++ ){
Object_and_primitive_id op = *it;
CGAL::Object object = op.first;
Point point;
if(CGAL::assign(point,object))
std::cout << "intersection object is a point : " << point << std::endl;
- [cgal-discuss] AABBTree primitives or objects problem, robertolam, 12/03/2009
- Re: [cgal-discuss] AABBTree primitives or objects problem, Camille Wormser, 12/03/2009
- Re: [cgal-discuss] AABBTree primitives or objects problem, Roberto Lam, 12/04/2009
- Re: [cgal-discuss] AABBTree primitives or objects problem, Camille Wormser, 12/04/2009
- Re: [cgal-discuss] AABBTree primitives or objects problem, Joe C, 12/04/2009
- Re: [cgal-discuss] AABBTree primitives or objects problem, Joe C, 12/07/2009
