cgal-discuss - Re: [cgal-discuss] CGAL + Visual Studio 2k8 Pro : Lib Error
  • To:
  • Subject: Re: [cgal-discuss] CGAL + Visual Studio 2k8 Pro : Lib Error
  • Date: Mon, 07 Dec 2009 17:35:53 +0100
  • Organization: INFOTERRA
Hi Michael,
Try to add
LIBS += pspapi.lib
to your .pro file.
Regards,
Laurent S.
Michael Jeulin-L wrote:
No, actually I`m directly using the .pro like they advice to do on the website ^^).
I`ll try differently.
Laurent Saboret wrote:
Are you using CMake?
Laurent
Hi,
You need pspapi.lib and QGLViewer libraries.
Best regards,
Laurent Saboret
Hi,
after lots of works to change development platform, I met 2 linkage problems
that I don`t understand and with which I don`t succeed to resolve :
error LNK2019: symbole externe non résolu
_GetProcessMemoryInfo@12
référencé dans la fonction "private: unsigned int __thiscall
CGAL::Memory_sizer::get(bool)const " (?get@Memory_sizer@CGAL@@ABEI_N@Z)
error LNK2001: symbole externe non résolu
error LNK2019: symbole externe non résolu "__declspec(dllimport) public:
__thiscall QGLViewer::QGLViewer(class QWidget *,char const *,class QGLWidget
const *,class QFlags<enum Qt::WindowType>)"
(__imp_??0QGLViewer@@QAE@PAVQWidget@@PBDPBVQGLWidget@@V?$QFlags@W4WindowType@Qt@@@@@Z)
référencé dans la fonction "public: __thiscall GLViewer::GLViewer(class
QWidget *)"
(??0GLViewer@@QAE@PAVQWidget@@@Z)
Does someone already see this kind of error, could someone help me to resolve
this problem ?
Thank you very much.
Regards.
Michael Jeulin-L.
Hi,
I already have the QGLViewer libraries and include QGLviewer2.lib (without this one I have of course a lots more of unresolved symbols) - So the error may come from a bad compilation of this one ? -
Concerning psapi.lib, could you just let me know how do you know that please, cause I didn`t find this information with looking for "GetProcessMemoryInfo@12 " on the net.
Thank You Very much, I just still have to see about the QGLViewer depedencie.
Best Regards.
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in
any contract or obligation, nor its subsidiaries.
