cgal-discuss - Re: [cgal-discuss] CGAL + Visual Studio 2k8 Pro : Lib Error
  • To:
  • Subject: Re: [cgal-discuss] CGAL + Visual Studio 2k8 Pro : Lib Error
  • Date: Tue, 08 Dec 2009 08:48:00 +0200
Laurent Saboret wrote:
Hi Michael,
Try to add
LIBS += pspapi.lib
to your .pro file.
Regards,
Laurent S.
Michael Jeulin-L wrote:
No, actually I`m directly using the .pro like they advice to do on the website ^^).
I`ll try differently.
Are you using CMake?
Laurent
Hi,
You need pspapi.lib and QGLViewer libraries.
Best regards,
Laurent Saboret
Hi,
after lots of works to change development platform, I met 2 linkage problems
that I don`t understand and with which I don`t succeed to resolve :
error LNK2019: symbole externe non résolu
_GetProcessMemoryInfo@12
référencé dans la fonction "private: unsigned int __thiscall
CGAL::Memory_sizer::get(bool)const " (?get@Memory_sizer@CGAL@@ABEI_N@Z)
error LNK2001: symbole externe non résolu
error LNK2019: symbole externe non résolu "__declspec(dllimport) public:
__thiscall QGLViewer::QGLViewer(class QWidget *,char const *,class QGLWidget
const *,class QFlags<enum Qt::WindowType>)"
(__imp_??0QGLViewer@@QAE@PAVQWidget@@PBDPBVQGLWidget@@V?$QFlags@W4WindowType@Qt@@@@@Z)
référencé dans la fonction "public: __thiscall GLViewer::GLViewer(class
QWidget *)"
(??0GLViewer@@QAE@PAVQWidget@@@Z)
Does someone already see this kind of error, could someone help me to resolve
this problem ?
Thank you very much.
Regards.
Michael Jeulin-L.
Hi,
I already have the QGLViewer libraries and include QGLviewer2.lib (without this one I have of course a lots more of unresolved symbols) - So the error may come from a bad compilation of this one ? -
Concerning psapi.lib, could you just let me know how do you know that please, cause I didn`t find this information with looking for "GetProcessMemoryInfo@12 " on the net.
Thank You Very much, I just still have to see about the QGLViewer depedencie.
Best Regards.
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
No, I meant that I use the .pro to compile QGLViewer (.lib).
To compile my project I`m just using msvc-2008 and with including psapi.lib directly into the project .
No I just have the following error :
référencé dans la fonction "public: __thiscall GLViewer::GLViewer(class QWidget *)" (??0GLViewer@@QAE@PAVQWidget@@@Z)
SO, I think that`s a problem in the compilation of QGLViewer.
Did you mean that I have to include psapi into the .pro of QGLViewer ?
Regards.
Michael Jeulin-L, ComputaMaps
Private Bag X20, Constantia 7848, South Africa
tel: +27.21.700 8140, fax: +27.21.701 9520, cell: +27.72.8588181
e-mail:
Manufacturers of digital maps and imagery
http://www.computamaps.com
