- To:
- Subject: Re: [cgal-discuss] Problems drawing Delaunay Triangulation
- Date: Tue, 8 Dec 2009 18:35:03 +0100
On Tuesday 08 December 2009 18:27:24 Ariel Baez wrote:
> Going from memory, but when drawing the triangles if you are drawing a
> bunch of them, OpenGL needs three points for the first triangle, but only
> needs an additional point for the next triangle, since OpenGL will use
> point #2 and point #3 of your first triangle for the first two points of
> the next triangle. This can be turned off, but I dont recall exactly how
> this is performed (GL_PROPERTY)
If you use:
glBegin(GL_TRIANGLE_STRIP);
glEnd();
then you are drawing a triangle strip (what you described).
If you want to draw triangles:
glBegin(GL_TRIANGLES);
glEnd();
then that is triangles that you are drawing.
Laurent Rineau, PhD
- [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/05/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Laurent Rineau (GeometryFactory), 12/05/2009
- Re: Re: [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/05/2009
- Re: Re: Re: [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/08/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Laurent Rineau (GeometryFactory), 12/08/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Ariel Baez, 12/08/2009
