- To:
- Subject: Re: [cgal-discuss] Problems drawing Delaunay Triangulation
- Date: Tue, 8 Dec 2009 12:40:06 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=UFs3ffHQX2sa2o3lMlg+zFGGeS8/8DrHI1OncyXkXLTaXivfsiSHj58dsGqlWRb1OP sUv/vXomMpkCHfmhsw/N0mWN7wiPEQmBIW9CkCpjgWjECVIEiHWLAvTsUZMDR6Jz7JdL M8xwybzVOAu/OyU61fJiUMS4R3qI4A1IEUh5U=
Thanks!
On Tue, Dec 8, 2009 at 12:35 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Tuesday 08 December 2009 18:27:24 Ariel Baez wrote:If you use:
> Going from memory, but when drawing the triangles if you are drawing a
> bunch of them, OpenGL needs three points for the first triangle, but only
> needs an additional point for the next triangle, since OpenGL will use
> point #2 and point #3 of your first triangle for the first two points of
> the next triangle. This can be turned off, but I dont recall exactly how
> this is performed (GL_PROPERTY)
glBegin(GL_TRIANGLE_STRIP);
glEnd();
then you are drawing a triangle strip (what you described).
If you want to draw triangles:
glBegin(GL_TRIANGLES);
glEnd();
then that is triangles that you are drawing.
Laurent Rineau, PhD
- [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/05/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Laurent Rineau (GeometryFactory), 12/05/2009
- Re: Re: [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/05/2009
- Re: Re: Re: [cgal-discuss] Problems drawing Delaunay Triangulation, dsilva.vinicius, 12/08/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Laurent Rineau (GeometryFactory), 12/08/2009
- Re: [cgal-discuss] Problems drawing Delaunay Triangulation, Ariel Baez, 12/08/2009
