cgal-discuss - Re: [cgal-discuss] 3D Delaunay Triangulations
  • To:
  • Subject: Re: [cgal-discuss] 3D Delaunay Triangulations
  • Date: Tue, 08 Dec 2009 23:26:05 +0100
Panagiotis Foteinos a écrit :
1) When a new tetrahedron, say t, is created: Is a new Cell_handle
allocated to accommodate t, or Cell_handle might point to a previously
allocated (but not currently used for any tetrahedron accommodation)
memory? I am asking because it would be ideal for my purposes, if no new
tetrahedron takes info() values from an old one...
It is the case in the current implementation, yes.
Some notes, however :
- I think it is not the case during the "bootstrapping phase",
when going from dimension 1 to 2 and 2 to 3.
- Delaunay_triangulation_2 currently differs here.
- we may change this in the future, for efficiency reasons,
but it's not clear yet when, nor for what exact behavior.
2) When a Vertex_handle, say v, is inserted: Does a Cell_handle,
accommodating a tetrahedron outside the cavity/hole of v, point to
another memory address after v's insertion? The answer should be
negative, just making sure...
Definitely negative. Cells outside the conflict hole are only changed
in the neighbor pointers that need to be changed.
2) When a Vertex_handle, say v, is deleted: Does a Cell_handle,
accommodating a tetrahedron outside the hole to be retriangulated, point
to another memory address after v's removal? The answer should be
Negative as well.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
