cgal-discuss - Re: [cgal-discuss] Having trouble building examples VS2008, missing boost library ...
  • To:
  • Subject: Re: [cgal-discuss] Having trouble building examples VS2008, missing boost library ...
  • Date: Wed, 09 Dec 2009 17:23:40 +0100
Hi Anthony,
when you install Boost you should check the Boost thread libs.
I'd say you should reinstall it with Boost thread which is not tiked by default.
Cheers,
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161 Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
Anthony Palomba a écrit :
I am getting a lot of errors when I try to build the CGAL example code.
It looks like it is trying to link to a boost library that is not present. I installed
the Boost 1.33.1 as instructed in the CGAL documentation. Is there something
I am missing here? The closest lib that the Boost 1.33.1 installer installs is
libboost_thread-vc80-mt-s-1_33_1.lib. Where is this library reference created?
It Can someone please help me?
7>------ Build started: Project: using_fair_splitting_rule, Configuration: Debug Win32 ------
7>Compiling...
7>using_fair_splitting_rule.cpp
6>Compiling manifest to resources...
6>Linking...
6>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc80-mt-gd-1_33_1.lib'
6>Build log was saved at "file://c:\development\CGAL files\examples\Voronoi_diagram_2\vd_2_point_location.dir\Debug\BuildLog.htm"
6>vd_2_point_location - 1 error(s), 0 warning(s)
7>Compiling manifest to resources...
7>Linking...
7>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc80-mt-gd-1_33_1.lib'
7>Build log was saved at "file://c:\development\CGAL files\examples\Spatial_searching\using_fair_splitting_rule.dir\Debug\BuildLog.htm"
7>using_fair_splitting_rule - 1 error(s), 0 warning(s)
