Re: [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect
- To:
- Subject: Re: [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect
- Date: Thu, 10 Dec 2009 09:24:28 -0800
- Organization: INRIA
hi Ramin, I see the problem. in your file cgal3-5/include/cgal/aabb_intersections.h comment the line #include <CGAL/AABB_intersections/Bbox_3_bbox_3_do_intersect.h> we'll fix this. thank you, Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Ramin H a écrit : I made a mini version of my project to reproduce this error. I am attaching the project to this message. (test-cgal.tar.gz) To test, extract the tar.gz file and do the following: (You may need to edit the path to CGAL in test-cgal.pro) $ qmake test-cgal.pro $ make I really appreciate it if you can help me find out why CGAL is behaving like this and if you know a work around. Thank you. -Ramin On Thu, Dec 10, 2009 at 10:39 AM, Ramin H wrote:Hi everyone, I have a project that uses CGAL-3.5. The project compiles completely but when linking, I get errors that I can not make sens of: ------------------------------ rintersectionset.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)': rintersectionset.cpp:(.text+0x0): multiple definition of `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)' main.o:main.cpp:(.text+0x0): first defined here rmainwindow.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)': rmainwindow.cpp:(.text+0x0): multiple definition of `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)' main.o:main.cpp:(.text+0x0): first defined here rmodel.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)': rmodel.cpp:(.text+0x0): multiple definition of `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)' main.o:main.cpp:(.text+0x0): first defined here RMeshPolyhedralDomain.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)': RMeshPolyhedralDomain.cpp:(.text+0x0): multiple definition of `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)' main.o:main.cpp:(.text+0x0): first defined here moc_rmainwindow.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)': moc_rmainwindow.cpp:(.text+0x0): multiple definition of `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)' main.o:main.cpp:(.text+0x0): first defined here collect2: ld returned 1 exit status make: *** [mesh01] Error 1 ----------------------------- and the main.cpp is: ------------- #include "rmainwindow.h" #include <QApplication> #include <QtOpenGL> #include <QtDebug> int main( int argc, char *argv[] ) { QApplication app(argc,argv); RMainWindow mainWin; mainWin.show(); return app.exec(); } ----------- Why is the compiler complaining about CGAL::do_intersect being already defined in main.cpp? Thank you, -Ramin |
- [cgal-discuss] compiler complains about multiple definition of CGAL::do_intersect, Ramin H, 12/10/2009
- [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect, Ramin H, 12/10/2009
- Re: [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect, Pierre Alliez, 12/10/2009
