cgal-discuss - Re: [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect
  • To:
  • Subject: Re: [cgal-discuss] Re: compiler complains about multiple definition of CGAL::do_intersect
  • Date: Thu, 10 Dec 2009 12:42:31 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=fJoQ7QnhlBkeNyIeLYFdzT9UwT/Mm1MRCDBJ6Lmv/pVbEo9bMOp8QmpHedvhCCrWQL R4VfLY5fTwcxHEEEQndMnIS4woYk1t67130/FQsLJ3RGmkAlTJrFI78Guzl/j+UWEMJd bodge0e7ur3b5pcXjXZL6JSmrvGcdt91WJ5Ps=
Thanks a lot Pierre. That solved the problem.
On Thu, Dec 10, 2009 at 12:24 PM, Pierre Alliez
wrote:
> hi Ramin,
> I see the problem.
> in your file cgal3-5/include/cgal/aabb_intersections.h
> comment the line
> #include <CGAL/AABB_intersections/Bbox_3_bbox_3_do_intersect.h>
> we'll fix this.
> thank you,
> Pierre Alliez
> INRIA Sophia Antipolis - Mediterranee
> Project-team GEOMETRICA
> http://www-sop.inria.fr/members/Pierre.Alliez/
> Tel: +33 4 92 38 76 77
> Fax: +33 4 97 15 53 95
> Ramin H a écrit :
> I made a mini version of my project to reproduce this error. I am
> attaching the project to this message. (test-cgal.tar.gz)
> To test, extract the tar.gz file and do the following:
> (You may need to edit the path to CGAL in test-cgal.pro)
> $ qmake test-cgal.pro
> $ make
> I really appreciate it if you can help me find out why CGAL is
> behaving like this and if you know a work around.
> Thank you.
> -Ramin
> On Thu, Dec 10, 2009 at 10:39 AM, Ramin H
> wrote:
> Hi everyone,
> I have a project that uses CGAL-3.5. The project compiles completely
> but when linking, I get errors that I can not make sens of:
> rintersectionset.o: In function `CGAL::do_intersect(CGAL::Bbox_3
> const&, CGAL::Bbox_3 const&)':
> rintersectionset.cpp:(.text+0x0): multiple definition of
> `CGAL::do_intersect(CGAL::Bbox_3 const&, CGAL::Bbox_3 const&)'
> main.o:main.cpp:(.text+0x0): first defined here
> rmainwindow.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&,
> rmainwindow.cpp:(.text+0x0): multiple definition of
> rmodel.o: In function `CGAL::do_intersect(CGAL::Bbox_3 const&,
> rmodel.cpp:(.text+0x0): multiple definition of
> RMeshPolyhedralDomain.o: In function `CGAL::do_intersect(CGAL::Bbox_3
> RMeshPolyhedralDomain.cpp:(.text+0x0): multiple definition of
> moc_rmainwindow.o: In function `CGAL::do_intersect(CGAL::Bbox_3
> moc_rmainwindow.cpp:(.text+0x0): multiple definition of
> collect2: ld returned 1 exit status
> make: *** [mesh01] Error 1
> and the main.cpp is:
> #include "rmainwindow.h"
> #include <QApplication>
> #include <QtOpenGL>
> #include <QtDebug>
> int main( int argc, char *argv[] )
>    QApplication app(argc,argv);
>    RMainWindow mainWin;
>    mainWin.show();
>    return app.exec();
> Why is the compiler complaining about CGAL::do_intersect being already
> defined in main.cpp?
> Thank you,
> -Ramin
