cgal-discuss - [cgal-discuss] 2D Mesh generation and triangles at boundaries.
  • To:
  • Subject: [cgal-discuss] 2D Mesh generation and triangles at boundaries.
  • Date: Fri, 11 Dec 2009 07:58:03 -0800 (PST)
Hi,
I have just started to use CGAL for mesh generation in my Computational
Fluid Dynamics (CFD) case. I need to generate a triangular mesh for a depth
integrated equation, so the size of the triangles depends on the local
depth. To solve this problem I generate a initial mesh
(Constrained_Delaunay_triangulation_2) using big triangles and I include all
the vertex of the triangulation into a list of points. Then I check the size
of each triangle and when the size is bigger than required, I include the
centroid of the triangle to the list and generate a new triangulation using
the points in the list. I continue this iterative process until the sizes of
all triangles fit the requirement. Can anyone suggest a better method to do
so?
Once the mesh is generated I have to write into a file the nodes and faces
of the triangulation which I have already solved. I have to write also the
segments of the triangles that are at the boundaries. The case I'm working
on is quite easy (rectangular domain) and I have solved it using the
line_walk method applied to the 4 lines defining my domain. I am afraid that
this won't work with a more complicate domain... :) Does anyone knows a more
general method?
Thanks a lot!!!
José.
View this message in context:
http://n4.nabble.com/2D-Mesh-generation-and-triangles-at-boundaries-tp961174p961174.html
