cgal-discuss - Re: [cgal-discuss] 2D Mesh generation and triangles at boundaries.
  • To:
  • Subject: Re: [cgal-discuss] 2D Mesh generation and triangles at boundaries.
  • Date: Tue, 15 Dec 2009 11:17:32 +0100
On Tuesday 15 December 2009 10:34:52 José wrote:
> Hi Panagiotis,
> Thanks for your reply.
> The problem I see is that the size criterion is constant for the whole
> domain. Am I wrong?
You are partially wrong. The function CGAL::refine_Delaunay_mesh_2 is a
function template. The second parameter is the criteria. CGAL Mesh_2 package
provides a class of criteria whose size criterion is constant for the whole
domain: you are right for that part. But you can create another class for
criteria, where the size criterion is a non constant function.
Laurent Rineau, PhD
