- To:
- Subject: Re: [cgal-discuss] visualizing the Mesh
- Date: Tue, 15 Dec 2009 19:43:40 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=aa55H2uoJ6CtxYqlQ4RGa+tDQTWC2nUTPpJXVIS6v781VREgC7pnzbm3KJg/FAEuJ+ x32Na16HPryWcumuId4p6XY0EWGMtMr/0FQ65CEXdpaSmOiIqqA/J0Q5ajMu8zksQpX7 y0rBEXFB2REsNau6u6YoF67yVdF9/b+X7CWsg=
Hi Tina,
If the output is a .off file, you may use Geomview. http://www.geomview.org/
If it's a .mesh file, you may use medit. You may find it here
http://www.ann.jussieu.fr/~frey/software.html
Hope this helps,
-Ramin
On Tue, Dec 15, 2009 at 7:11 PM, tina rumi
wrote:
> Hi every one,
> I need to visulize the result of surface reconstruction like this:
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
> Can anybody help me with that? I appreciate it.
> Thanks,
> Tina
- [cgal-discuss] visualizing the Mesh, tina rumi, 12/16/2009
- Re: [cgal-discuss] visualizing the Mesh, Ramin H, 12/16/2009
- Re: [cgal-discuss] visualizing the Mesh, Laurent Saboret, 12/16/2009
- Re: [cgal-discuss] visualizing the Mesh, Laurent Rineau (GeometryFactory), 12/16/2009
