- To:
- Subject: Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh
- Date: Thu, 17 Dec 2009 17:45:57 +0100
On Wednesday 16 December 2009 18:04:56 Ramin H wrote:
> I looked at Mesh_criteria_3.h, Mesh_facet_criteria_3.h and
> Mesh_cell_criteria_3.h. As far as I understand, these are the default
> meshing criteria defined in CGAL package for Mesh_3 process.
> This is how Mesh_cell_criteria_3's constructor looks like:
> Mesh_cell_criteria_3(const FT& radius_edge_bound,
> const FT& radius_bound)
> so, we realize that radius_edge_bound and radius_bound are functors.
No they are not functors! They are a const reference to a FT (field type).
With most CGAL kernels, "FT" is equal to "double".
> Now, going back to
> CGAL-3.5/examples/Mesh_3/mesh_polyhedral_domain.cpp, is it possible to
> define the following and expect this to just work?
> typedef K::FT FT;
> typedef FT (Function)(const Point&);
> FT function_1 (const Point& p)
> const FT x1=p.x();
> const FT y1=p.y();
> const FT z1=p.z();
> return x1+y1+z1+1;
Be careful with that example: that size field is zero along the plane of
equation x+y+z-1=0, and is negative on the negative size of that plane!
> and then in main.cpp,
> int main()
> Cell_criteria cell_criteria(function_1, 0.2);
> I appreciate your feedback.
No, that is not possible as-is. You need to define your own model of the
concept MeshCriteria_3.
Laurent Rineau, PhD
- [cgal-discuss] parametric mesh criteria for 3D mesh, Ramin H, 12/15/2009
- [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/16/2009
- [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/17/2009
- Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Laurent Rineau (GeometryFactory), 12/17/2009
- Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/17/2009
