- To:
- Subject: Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh
- Date: Thu, 17 Dec 2009 12:05:01 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=XCrMS45pW8nzjheJTOZ5sORs7TnkBYBBp/S3UsxNIgYxGvy0nGQ8aBDnPqaEoSrpv4 lLGxszlchJyjvl6asisKyvj4ypkQUEyUbNFKv3Cbzdi0cunmHFVeVVttDAKvlsp/hCSY oFkFnd32fXZfgrxQsG8LwQ7kn9Jrfsw+YeRPA=
Thank you very much Laurent. I appreciate your help.
I will dig further to see how I should use concept MeshCriteria_3 to
implement this.
I wish there was similar attempt for surface mesh or 2D meshing so I
could see how this is done.
Thanks again,
-Ramin
On Thu, Dec 17, 2009 at 11:45 AM, Laurent Rineau (GeometryFactory)
wrote:
> On Wednesday 16 December 2009 18:04:56 Ramin H wrote:
>> I looked at Mesh_criteria_3.h, Mesh_facet_criteria_3.h and
>> Mesh_cell_criteria_3.h. As far as I understand, these are the default
>> meshing criteria defined in CGAL package for Mesh_3 process.
>> This is how Mesh_cell_criteria_3's constructor looks like:
>> Mesh_cell_criteria_3(const FT& radius_edge_bound,
>> const FT& radius_bound)
>> so, we realize that radius_edge_bound and radius_bound are functors.
> No they are not functors! They are a const reference to a FT (field type).
> With most CGAL kernels, "FT" is equal to "double".
>> Now, going back to
>> CGAL-3.5/examples/Mesh_3/mesh_polyhedral_domain.cpp, is it possible to
>> define the following and expect this to just work?
>> typedef K::FT FT;
>> typedef FT (Function)(const Point&);
>> FT function_1 (const Point& p)
>> const FT x1=p.x();
>> const FT y1=p.y();
>> const FT z1=p.z();
>> return x1+y1+z1+1;
> Be careful with that example: that size field is zero along the plane of
> equation x+y+z-1=0, and is negative on the negative size of that plane!
>> and then in main.cpp,
>> int main()
>> Cell_criteria cell_criteria(function_1, 0.2);
>> I appreciate your feedback.
> No, that is not possible as-is. You need to define your own model of the
> concept MeshCriteria_3.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] parametric mesh criteria for 3D mesh, Ramin H, 12/15/2009
- [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/16/2009
- [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/17/2009
- Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Laurent Rineau (GeometryFactory), 12/17/2009
- Re: [cgal-discuss] Re: parametric mesh criteria for 3D mesh, Ramin H, 12/17/2009
