cgal-discuss - Re: [cgal-discuss] how to construct equidistant curves???
  • To:
  • Subject: Re: [cgal-discuss] how to construct equidistant curves???
  • Date: Wed, 30 Dec 2009 10:48:51 +0100
Le mardi 29 décembre 2009 04:37:39, myth0904 a écrit :
> hi, everyone!
> is their any sulution in CGAL for constructing equidistant curves?
> The question is:
> I have a base curve described by spline, such as cardinal spline.
> Given a point, a new curve is constructed which passes the given point and
> is equidistanct from the base curve.
> any suggestion will be appreciated!!
As far as I know, splines are constructed from a control polygon. If you want
to translate your spline, you may just have to translate the control polygon.
But, If you really want a spline which is equidistant from the first spline,
you should read articles about offsets of splines, see:
http://scholar.google.com/scholar?q=spline%20offset
Laurent Rineau, PhD
