cgal-discuss - Re: [cgal-discuss] how to construct equidistant curves???
  • To:
  • Subject: Re: [cgal-discuss] how to construct equidistant curves???
  • Date: Wed, 30 Dec 2009 17:56:24 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Q0PPkrJWrjgCQBYkN8lKt+R77qCAOY1YGkKXR+1ehMR+IL4fvSb11D1+uhVpReJppH oBT2aDnG7POAVVa+1Kd1SnU8dMGgfCoGPv7XY81bXx6NDsfCCRyXv2deqiHozPRhsAzm mHUj02jR/tugYpmfn+KPGcGVaEx3BQuTHWO9Y=
Hi, everyone!
Did someone port CGAL to embeded systems such as WinCE ? If did, how about the performance ?
Best Regards
2009/12/30 Laurent Rineau (GeometryFactory) <>
Le mardi 29 décembre 2009 04:37:39, myth0904 a écrit :
> hi, everyone!
> is their any sulution in CGAL for constructing equidistant curves?
> The question is:
> I have a base curve described by spline, such as cardinal spline.
> Given a point, a new curve is constructed which passes the given point and
>  is equidistanct from the base curve.
> any suggestion will be appreciated!!
As far as I know, splines are constructed from a control polygon. If you want
to translate your spline, you may just have to translate the control polygon.
But, If you really want a spline which is equidistant from the first spline,
you should read articles about offsets of splines, see:
 http://scholar.google.com/scholar?q=spline%20offset
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
