- To:
- Subject: Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4
- Date: Tue, 5 Jan 2010 18:42:50 +0100
On Tuesday 05 January 2010 18:31:47 Joe C wrote:
> Can is_valid() tell this (returning false)? The polyhedron
> intersect_poly_1.off was the output of a polyhedron which shows true when
> running against is_valid().
Yes, as far as I know the is_valid function of the CGAL polyhedron class only
checks the combinatorial integrity. But other algorithms of CGAL (such as the
conversion from a regular polyhedron to a nef polyhedron) may need more. In
your case, I have seen overlapping facets. I am not surprised that the
constructor of Nef_3 cannot deal with that sort of data.
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4, Joe C, 01/05/2010
- Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4, Laurent Rineau (GeometryFactory), 01/05/2010
