- To: "Laurent Rineau (GeometryFactory)" <>,
- Subject: Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4
- Date: Tue, 5 Jan 2010 09:31:47 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=okjqIEqgTELBqNzGDvB60/+VHSQIPjIzxbw82OgKXaRJGJZNYmWvyCw7ymR1eEu0Hf 0tPdwvtZdOa0kFeH+BN2VlM4yBroR+sXVx5jjETw+mdH3BxLiR6kqD73uglxCiWFOYfm We0fd/Bughlu/TAYgBqP5Jl7AKkClBA43ECHw=
Can is_valid() tell this (returning false)? The polyhedron intersect_poly_1.off was the output of a polyhedron which shows true when running against is_valid().
On Tue, Jan 5, 2010 at 2:00 AM, Laurent Rineau (GeometryFactory) <> wrote:
As far as I can see, the polyhedron intersect_poly_1.off is not
combinatorially a polyhedron: it has overlaping facets.
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4, Joe C, 01/05/2010
- Re: [cgal-discuss] Re: Intersection failed on Nef_polyhedron_3, CGAL 3.4, Laurent Rineau (GeometryFactory), 01/05/2010
