- To:
- Subject: Re: [cgal-discuss] 3D cloud points triangulation
- Date: Wed, 6 Jan 2010 20:22:03 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ue0w7BiPZ8CkXdMX4LM6DZSYkPfMlYZ2JTYYDrJRcUjbSeHoshtCvnfjyenre49jYX D83C3K+SsyFuNQEqmJyLOgVUzd8KdFjJKffJL25rLg0q3kKKVgSfmTllwPt83/F6XLUs 7uS9chzIY2IQQxBX6xpfXF0rUiIPr0uXaFq1g=
Hi Nader,
Thanks a lot for the tips. Actually I was using Manifold_with_boundary_tag, but I had that problem. I tried Non_manifold_tag but it didn't work and when I used the Manifold_tag, result was exactly like Manifold_with_boundary_tag.
I am saving data as polyhedron.
I would like to have the result like "nefertiti.off" in "CGAL-3.5\examples\Surface_mesh_parameterization\data", which the borders are free and not connected.
Thank you,
Tina
On Wed, Jan 6, 2010 at 4:04 AM, Nader SALMAN <> wrote:
Dear Tina,
if i understood well, you tried to use the CGAL surface mesher (e.g. CGAL::make_surface_mesh).
If you use the oracle that intersects a polyhedron, the surface can be "open".
You should use the Manifold_with_boundary_tag (or the Non_manifold_tag), rather than the Manifold_tag
that tends to close the surface quote: "but after triangulation I will get a close object which all of the borders are connected".
Here is a link to the documentation : http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
Yours,
Nad.
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161 Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
tina rumi a écrit :--
Hi all,
I applied the cgal triangulation on the 3D cloud points that I have. My data is like a surface which is like open object but after triangulation I will get a close object which all of the borders are connected. Do you have any suggestion to solve that.
Thank you,
Tina
- [cgal-discuss] 3D cloud points triangulation, tina rumi, 01/06/2010
- RE: [cgal-discuss] 3D cloud points triangulation, LIANGJiayu, 01/06/2010
- Re: [cgal-discuss] 3D cloud points triangulation, Nader SALMAN, 01/06/2010
- Re: [cgal-discuss] 3D cloud points triangulation, tina rumi, 01/07/2010
- Re: [cgal-discuss] 3D cloud points triangulation, 杨成林, 01/06/2010
