- To:
- Subject: Re: [cgal-discuss] 3D cloud points triangulation
- Date: Wed, 06 Jan 2010 10:04:36 +0100
Dear Tina,
if i understood well, you tried to use the CGAL surface mesher (e.g. CGAL::make_surface_mesh).
If you use the oracle that intersects a polyhedron, the surface can be "open".
You should use the Manifold_with_boundary_tag (or the Non_manifold_tag), rather than the Manifold_tag
that tends to close the surface quote: "but after triangulation I will get a close object which all of the borders are connected".
Here is a link to the documentation : http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
Yours,
Nad.
Nader SALMAN
Geometrica Lab, Byron Y308
INRIA Sophia Antipolis (FRANCE)
Tel: +33(0)4 9238 7161 Fax: +33(0)4 9715 5395
http://www-sop.inria.fr/members/Nader.Salman
tina rumi a écrit :
Hi all,
I applied the cgal triangulation on the 3D cloud points that I have. My data is like a surface which is like open object but after triangulation I will get a close object which all of the borders are connected. Do you have any suggestion to solve that.
Thank you,
Tina
- [cgal-discuss] 3D cloud points triangulation, tina rumi, 01/06/2010
- RE: [cgal-discuss] 3D cloud points triangulation, LIANGJiayu, 01/06/2010
- Re: [cgal-discuss] 3D cloud points triangulation, Nader SALMAN, 01/06/2010
- Re: [cgal-discuss] 3D cloud points triangulation, tina rumi, 01/07/2010
- Re: [cgal-discuss] 3D cloud points triangulation, 杨成林, 01/06/2010
