- To:
- Subject: Re: [cgal-discuss] linear_least_squares_[23]
- Date: Fri, 15 Jan 2010 08:44:03 +0100
- Organization: INRIA
hi, for PCA in CGAL it is the default orthogonal projection. pierre Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 ganders a écrit : Hi Pierre, thanks for your reply, but I read this manual and it confuses me a bit and thus I had - and still have - this question. Looking at figure 1 on page 3 I. Markovsky and S. Van Huffel, Overview of total least squares methods, Signal Processing, Volume 87, pages 2283-2302, 2007. ftp://ftp.esat.kuleuven.ac.be/pub/SISTA/markovsky/reports/05-34.pdf the difference between LS and TLS is clearly described and obvious. The right TLS picture has a orthogonal projection, the left LS one does not. This CGAL manual is mentioning a LS - but not explicitely a TLS - with orthogonal projection. Interpreting your answer, I guess it is a TLS, right? Thanks in advance. Cheers, Gerd Pierre Alliez wrote:hi Gerd, the documentation of the PCA component (user manual <http://www.cgal.org/Manual/last/doc_html/cgal_manual/Principal_component_analysis/Chapter_main.html>) says: Given a set of objects, /linear least squares fitting/ amounts to finding the linear sub-space which minimizes the sum of squared distances from all points composing the objects of the set, to their projection onto this linear sub-space. Such linear sub-space is obtained by so-called principal component analysis (PCA). PCA is defined as a transformation that transforms the objects to a new coordinate system such that the greatest variance by orthogonal projection of the objects comes to lie on the first coordinate (called the first principal component), the second greatest variance on the second coordinate, and so on. pierre Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 ganders a écrit :Dear CGAL-team, I am searching for a method that calculates a fitting line in terms of a total-least-squares (TLS) approach for 3D points. As input I would like to provide a matrix with the x/y/z coordinates and as output I would like to receive two points describing the straight line. It looks that linear_least_squares_fitting_3 is exactly that what I am looking for. But I am not sure if it really calculates the TLS or the different linear-least-squares (LLS) solution. May I ask you to tell me what approach is implemented (TLS or LLS)? Thanks a lot in advance. Cheers, Gerd-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss |
- [cgal-discuss] linear_least_squares_[23], ganders, 01/13/2010
- Re: [cgal-discuss] linear_least_squares_[23], Pierre Alliez, 01/14/2010
- Re: [cgal-discuss] linear_least_squares_[23], ganders, 01/14/2010
- Re: [cgal-discuss] linear_least_squares_[23], Pierre Alliez, 01/15/2010
- Re: [cgal-discuss] linear_least_squares_[23], 杨成林, 01/15/2010
