cgal-discuss - Re: [cgal-discuss] linear_least_squares_[23]
  • To:
  • Subject: Re: [cgal-discuss] linear_least_squares_[23]
  • Date: Fri, 15 Jan 2010 20:17:23 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=MtAHBawR3bydc8iP5yPq3zcfiE6iSI1HQCAZ/nWsmpry+dzTLxaclNSB+ZxManO/q2 opLqic83M2ZHqMpWMOFwWv9VydJ56nX/AF+1A61gekYu3WhRBfRqV+FDU7fV4YBIef7n nfhfRlz2n74tE7N3EHKiQXlTNo0UHh+9d2SmQ=
PCA in CGAL is TLS, I think.
2010/1/15, Pierre Alliez
> hi,
> for PCA in CGAL it is the default orthogonal projection.
> pierre
> Pierre Alliez
> INRIA Sophia Antipolis - Mediterranee
> Project-team GEOMETRICA
> http://www-sop.inria.fr/members/Pierre.Alliez/
> Tel: +33 4 92 38 76 77
> Fax: +33 4 97 15 53 95
> ganders a écrit :
>> Hi Pierre,
>> thanks for your reply, but I read this manual and it confuses me a bit and
>> thus I had - and still have - this question. Looking at figure 1 on page 3
>> I. Markovsky and S. Van Huffel, Overview of total least squares methods,
>> Signal Processing, Volume 87, pages 2283-2302, 2007.
>> ftp://ftp.esat.kuleuven.ac.be/pub/SISTA/markovsky/reports/05-34.pdf
>> the difference between LS and TLS is clearly described and obvious. The
>> right TLS picture has a orthogonal projection, the left LS one does not.
>> This CGAL manual is mentioning a LS - but not explicitely a TLS - with
>> orthogonal projection. Interpreting your answer, I guess it is a TLS,
>> right?
>> Thanks in advance.
>> Cheers,
>> Gerd
>> Pierre Alliez wrote:
>>> hi Gerd,
>>> the documentation of the PCA component (user manual
>>> <http://www.cgal.org/Manual/last/doc_html/cgal_manual/Principal_component_analysis/Chapter_main.html>)
>>> says:
>>> Given a set of objects, /linear least squares fitting/ amounts to
>>> finding the linear sub-space which minimizes the sum of squared
>>> distances from all points composing the objects of the set, to their
>>> projection onto this linear sub-space. Such linear sub-space is obtained
>>> by so-called principal component analysis (PCA). PCA is defined as a
>>> transformation that transforms the objects to a new coordinate system
>>> such that the greatest variance by orthogonal projection of the objects
>>> comes to lie on the first coordinate (called the first principal
>>> component), the second greatest variance on the second coordinate, and
>>> so on.
>>> pierre
>>> Pierre Alliez
>>> ganders a écrit :
>>>> Dear CGAL-team,
>>>> I am searching for a method that calculates a fitting line in terms of a
>>>> total-least-squares (TLS) approach for 3D points. As input I would like
>>>> to
>>>> provide a matrix with the x/y/z coordinates and as output I would like
>>>> to
>>>> receive two points describing the straight line. It looks that
>>>> linear_least_squares_fitting_3 is exactly that what I am looking for.
>>>> But
>>>> I
>>>> am not sure if it really calculates the TLS or the different
>>>> linear-least-squares (LLS) solution. May I ask you to tell me what
>>>> approach
>>>> is implemented (TLS or LLS)? Thanks a lot in advance.
>>>> Cheers,
>>>> Gerd
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
杨成林
Yang Chenglin
