- To:
- Subject: Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3
- Date: Sat, 23 Jan 2010 15:02:09 +0100
Le 23/01/10 10:03, Edoardo Milotti a écrit :
I use Triangulation_hierarchy_3, and I insert vertices one by one in a
fixed order: I noticed that the triangulation output is shuffled and the
order is different every time I run my program. Can anybody please tell
me how to set the seed of the internal random number generator in order
to obtain a reproducible output? Thanks.
By "output order", you meant the Cell_iterator order, not
the Vertex_iterator order, right ?
Does the following patch solve your problem ?
--- Triangulation_3.h (revision 52267)
+++ Triangulation_3.h (working copy)
@@ -207,7 +207,6 @@
Tds _tds;
GT _gt;
Vertex_handle infinite; //infinite vertex
- mutable Random rng;
Comparison_result
compare_xyz(const Point &p, const Point &q) const
@@ -1501,6 +1500,8 @@
start = start->neighbor(ind_inf);
+ Random rng (0L);
switch (dimension()) {
case 3:
Sylvain Pion
INRIA Sophia Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] random number seed in Triangulation_hierarchy_3, Edoardo Milotti, 01/23/2010
- Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3, Sylvain Pion, 01/23/2010
- Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3, Edoardo Milotti, 01/25/2010
- Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3, Sylvain Pion, 01/25/2010
