cgal-discuss - Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3
  • To:
  • Subject: Re: [cgal-discuss] random number seed in Triangulation_hierarchy_3
  • Date: Mon, 25 Jan 2010 15:13:54 +0100
  • Organization: INRIA
Thanks Edoardo for confirming.
Actually, CGAL-3.6-beta1, to be released RSN, will contain this patch.
A priori, we do not see a need to offer access to these internal RNGs,
since they are only used for internal randomization (to guarantee
algorithm complexities). Nevertheless, we are aware of needs for
strong determinism of the output, and are thinking of appropriate fixes.
Le 25/01/10 15:01, Edoardo Milotti a écrit :
Dear Sylvain,
I have patched Triangulation_3.h as you suggested and now I get exactly the
same output, so I guess that this fixes the problem. Maybe in future versions
of CGAL you could add a function that lets the user set the seed of the
random number generator, this is important in Monte Carlo simulations such as
mine.
Thank you very much.
Best wishes,
Edoardo Milotti
On 25/gen/2010, at 12.54, Sylvain Pion wrote:
Dear Edoardo,
Can you please try what I suggested and report on the results ?
Le 25/01/10 09:00, Edoardo Milotti a écrit :
Dear Sylvain , thank very much you for you answer, however I have one
further question.
I insert points in the triangulation as follows (to maintain the
original order I use a sequential insertion)
for(vector<Point>::iterator it=v.begin(); it!=v.end(); it++)
T.insert(*it);
I add vertex info
for (Finite_vertices_iterator vit = T.finite_vertices_begin(); vit !=
T.finite_vertices_end(); ++vit)
vit->info() = k;
k++;
then I use the named vertices in a further loop
T.incident_vertices(vit, back_inserter(vn)); // list of named neighbors ...
... etc ...
The order of the list of finite incident vertices in the last loop turns
out different at some point, like this
first run
- 8 1.93693532e-11 9.08382265e-06 2.132290991e-06
- 5 3.478538238e-11 8.274341753e-06 4.204006e-06
- 10 1.273731276e-11 9.54219939e-06 1.334840348e-06
- 6 1.795678855e-11 9.23188419e-06 1.945083818e-06
- 9 2.62181266e-11 8.721762172e-06 3.006058419e-06
- 1 4.740207202e-12 1.002035364e-05 4.730578752e-07
- 0 7.036177754e-11 3.051055408e-06 2.306145518e-05
second run
here the first column is the vertex name, while the other three columns
contain geometric information, and in particular the second one is the
distance between the finite vertex under consideration and on of its
finite incident vertices. The distances are the same, only the order
appears to be shuffled. I guessed that this is due to the internal
random number generator, however I am no longer so sure now. I use long
double's to represent point coordinates (16 bytes): could it be some
type conversion and precision problem inside CGAL that determines a
different output order?
Thank you very much,
Edoardo Milotti
On 23/gen/2010, at 15.02, Sylvain Pion wrote:
Le 23/01/10 10:03, Edoardo Milotti a écrit :
I use Triangulation_hierarchy_3, and I insert vertices one by one in a
fixed order: I noticed that the triangulation output is shuffled and the
order is different every time I run my program. Can anybody please tell
me how to set the seed of the internal random number generator in order
to obtain a reproducible output? Thanks.
By "output order", you meant the Cell_iterator order, not
the Vertex_iterator order, right ?
Does the following patch solve your problem ?
--- Triangulation_3.h (revision 52267)
+++ Triangulation_3.h (working copy)
@@ -207,7 +207,6 @@
Tds _tds;
GT _gt;
Vertex_handle infinite; //infinite vertex
- mutable Random rng;
Comparison_result
compare_xyz(const Point&p, const Point&q) const
@@ -1501,6 +1500,8 @@
start = start->neighbor(ind_inf);
+ Random rng (0L);
switch (dimension()) {
case 3:
Sylvain Pion
INRIA Sophia Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Sylvain Pion
Sylvain Pion
