- To:
- Subject: Re: [cgal-discuss] Ridges and Umbilics on Triangulated Surface Meshes
- Date: Mon, 25 Jan 2010 21:20:04 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Pgha20mhQEtMz+NgVi4qqoyQNB7YZWBnWHFmNTu+nlV3Bo1jrJVhX6lkiVbGVm8Gdg HSLu/v+hJdJxMjRkCd56JeQ75bx0tibkE6YnK5Cm2klvRqv1AGrHn/Bh40twFmoCQ/LN k71uIs3vnDKXbD5NN9e/qtlf0tFiyKOuxbZz0=
Hi Marc,
Thanks for the reply. I never use QGLViewer. Do you know where can I find a demo for it.
Thanks,
Tina
On Thu, Jan 21, 2010 at 4:09 AM, Marc Pouget <> wrote:
Hi,this was an old visu tool, no longer maintainedNow what is becoming the recommended visu tool for cgal is QGLViewer. I've never used it but it is qt and opengl based so standart and you can find demo code, for polyhedron for instanceHope this helpbestMArcOn Jan 14, 2010, at 11:58 PM, tina rumi wrote:Hey Guys,
I am running the example which is to approximate ridges and umbilics on the meshes. I would like to visualize the result like Figure 52.1: (Crest ridges on the David) . in
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Ridges_3/Chapter_main.html
I couldn't find any demo for that in cgal demos or example. Does anybody know a fast way to visualize it.
Thanks,
Tina
- [cgal-discuss] Ridges and Umbilics on Triangulated Surface Meshes, tina rumi, 01/14/2010
- Re: [cgal-discuss] Ridges and Umbilics on Triangulated Surface Meshes, Marc Pouget, 01/21/2010
- Re: [cgal-discuss] Ridges and Umbilics on Triangulated Surface Meshes, tina rumi, 01/26/2010
- Re: [cgal-discuss] Ridges and Umbilics on Triangulated Surface Meshes, Andreas Fabri, 01/26/2010
