- To:
- Subject: Re: [cgal-discuss] Copying two different triangulation types.
- Date: Thu, 28 Jan 2010 09:01:04 +0100
Hello,
A clean integrated solution is on my TODO list. I can give you now an experimental piece of code I use (basically a copy-paste of the triangulation member function copy).
S.
Simon Perkins wrote:
Dear All
Is it possible to perform an exact copy of the vertices and cells between two different 3D Triangulation types? For example, I want to use the Mesh_3 package to tetrahedralize a domain and then copy the Mesh_3 Triangulation into a customized Triangulation_3. It doesn't seem possible to do this via the constructor, copy() and swap() functions. I also attempted this with the output and input streams, by outputting a Mesh_3 Triangulation and trying to input the same into a Triangulation_3, but this did not work due to a failed assertion.
regards
Simon
//build our internal TDS using the TDS of an already built triangulation //returns the number of vertices template <class TDS_src,class TDS_tgt> void copy_tds(const TDS_src& src,TDS_tgt& tgt,typename TDS_src::Vertex_handle s_infinite,typename TDS_tgt::Vertex_handle t_infinite) { int n = src.number_of_vertices(); if (n == 0) return; tgt.cells().clear(); tgt.set_dimension(src.dimension()); // Number of pointers to cell/vertex to copy per cell. int dim = (std::max)(1, tgt.dimension() + 1); // Create the vertices. std::vector<typename TDS_src::Vertex_handle> TV(n); int i = 0; for (typename TDS_src::Vertex_iterator vit = src.vertices_begin(); vit != src.vertices_end(); ++vit) TV[i++] = vit; CGAL_triangulation_assertion( i == n ); std::map< typename TDS_src::Vertex_handle, typename TDS_tgt::Vertex_handle > V; std::map< typename TDS_src::Cell_handle, typename TDS_tgt::Cell_handle > F; assert(TV[0]==s_infinite); assert(tgt.vertices_begin()==t_infinite); V[ TV[0] ] = t_infinite; for (i=1; i <= n-1; ++i){ typename TDS_tgt::Vertex_handle vh= tgt.create_vertex( typename TDS_tgt::Vertex(TV[i]->point()) ); V[ TV[i] ] = vh; } // Create the cells. for (typename TDS_src::Cell_iterator cit = src.cells_begin(); cit != src.cells_end(); ++cit) { //WE ARE LOOSING ALL INFO INSIDE CELL (HIDDEN POINT ETC...) F[cit] = tgt.create_cell(); for (int j = 0; j < dim; j++) F[cit]->set_vertex(j, V[cit->vertex(j)] ); } // Link the vertices to a cell. for (typename TDS_src::Vertex_iterator vit2 = src.vertices_begin(); vit2 != src.vertices_end(); ++vit2) V[vit2]->set_cell( F[vit2->cell()] ); // Hook neighbor pointers of the cells. for (typename TDS_src::Cell_iterator cit2 = src.cells_begin(); cit2 != src.cells_end(); ++cit2) { for (int j = 0; j < dim; j++) F[cit2]->set_neighbor(j, F[cit2->neighbor(j)] ); } CGAL_triangulation_postcondition( tgt.is_valid() ); }
- [cgal-discuss] Copying two different triangulation types., Simon Perkins, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Sebastien Loriot (GeometryFactory), 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Sylvain Pion, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Simon Perkins, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Laurent Rineau (GeometryFactory), 01/28/2010
