- To:
- Subject: Re: [cgal-discuss] Copying two different triangulation types.
- Date: Thu, 28 Jan 2010 12:03:16 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=gpgvoWcwI3Pqni24BeYyHXhYQfay5zQ+aNMbsHax9SNDOpj0/V7k37NyEXfjuVZWv0 lXhUOuGtF6CnodAHGwKcOhacW4XBObZMKMSkG7l7983+DP2EXER4f5hEd4UOzz2SYy2l 6rjwiQFOA1bQ/AJd8ix8VgTtdA4H80XSKirRY=
Thanks Sebastien, the code snippet works well.
Sylvain, you're correct that I could extend the Triangulation associated with the Mesh_3. My project was originally based on the Delaunay_triangulation_3 class in CGAL 3.4 and I wanted avoided refactoring at this point. But, I did want to try out Mesh_3 package in CGAL 3.5.1 to generate and use some random meshes.
With regard to the failed assertion, the following is produced when I try and read a triangulation from an ifstream
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: false
File: /home/simon/usr/local/include/CGAL/Triangulation_data_structure_3.h
Line: 2651
I've attached my current test program that produces it - its modified from the mesh_implicit_sphere.cpp example to mesh an implicit cube. I've also attached the output triangulation file.
regards
Simon
On Thu, Jan 28, 2010 at 10:36 AM, Sylvain Pion <> wrote:
Le 28/01/10 08:50, Simon Perkins a écrit :What is the problem ? Is it different point type, or different requirements
Dear All
Is it possible to perform an exact copy of the vertices and cells
between two different 3D Triangulation types? For example, I want to use
the Mesh_3 package to tetrahedralize a domain and then copy the Mesh_3
Triangulation into a customized Triangulation_3.
in the vertex/cell types ? In the latter case, it might also be possible
to combine the requirements on vertex/cell types in order to have one
triangulation type that works in both cases. Then you avoid the copy
completely."a failed assertion" ?
It doesn't seem
possible to do this via the constructor, copy() and swap() functions. I
also attempted this with the output and input streams, by outputting a
Mesh_3 Triangulation and trying to input the same into a
Triangulation_3, but this did not work due to a failed assertion.
Sylvain Pion
INRIA Sophia Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
/* * main.cpp * * Created on: 21 Jan 2010 * Author: simon */ #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/Implicit_mesh_domain_3.h> #include <CGAL/make_mesh_3.h> #include <CGAL/IO/Geomview_stream.h> #include <CGAL/IO/Triangulation_geomview_ostream_3.h> #include <CGAL/Triangulation_3.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::FT FT; typedef K::Point_3 Point_3; typedef FT(Function)(const Point_3 &); typedef CGAL::Implicit_mesh_domain_3<Function, K> Mesh_domain; typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3; typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria; typedef Mesh_criteria::Facet_criteria Facet_criteria; typedef Mesh_criteria::Cell_criteria Cell_criteria; FT cube_function(const Point_3 & p) { if(0.0f <= p.x() && p.x() <= 1.0 && 0.0f <= p.y() && p.y() <= 1.0 && 0.0f <= p.z() && p.z() <= 1.0) { return -1.0f; } return 1.0f; } //build our internal TDS using the TDS of an already built triangulation //returns the number of vertices template <class TDS_src,class TDS_tgt> void copy_tds(const TDS_src& src,TDS_tgt& tgt,typename TDS_src::Vertex_handle s_infinite,typename TDS_tgt::Vertex_handle t_infinite) { int n = src.number_of_vertices(); if (n == 0) return; tgt.cells().clear(); tgt.set_dimension(src.dimension()); // Number of pointers to cell/vertex to copy per cell. int dim = (std::max)(1, tgt.dimension() + 1); // Create the vertices. std::vector<typename TDS_src::Vertex_handle> TV(n); int i = 0; for (typename TDS_src::Vertex_iterator vit = src.vertices_begin(); vit != src.vertices_end(); ++vit) TV[i++] = vit; CGAL_triangulation_assertion( i == n ); std::map< typename TDS_src::Vertex_handle, typename TDS_tgt::Vertex_handle > V; std::map< typename TDS_src::Cell_handle, typename TDS_tgt::Cell_handle > F; assert(TV[0]==s_infinite); assert(tgt.vertices_begin()==t_infinite); V[ TV[0] ] = t_infinite; for (i=1; i <= n-1; ++i){ typename TDS_tgt::Vertex_handle vh= tgt.create_vertex( typename TDS_tgt::Vertex(TV[i]->point()) ); V[ TV[i] ] = vh; } // Create the cells. for (typename TDS_src::Cell_iterator cit = src.cells_begin(); cit != src.cells_end(); ++cit) { //WE ARE LOOSING ALL INFO INSIDE CELL (HIDDEN POINT ETC...) F[cit] = tgt.create_cell(); for (int j = 0; j < dim; j++) F[cit]->set_vertex(j, V[cit->vertex(j)] ); } // Link the vertices to a cell. for (typename TDS_src::Vertex_iterator vit2 = src.vertices_begin(); vit2 != src.vertices_end(); ++vit2) V[vit2]->set_cell( F[vit2->cell()] ); // Hook neighbor pointers of the cells. for (typename TDS_src::Cell_iterator cit2 = src.cells_begin(); cit2 != src.cells_end(); ++cit2) { for (int j = 0; j < dim; j++) F[cit2]->set_neighbor(j, F[cit2->neighbor(j)] ); } CGAL_triangulation_postcondition( tgt.is_valid() ); } int main(int argc, char * argv[]) { Mesh_domain domain(cube_function, K::Sphere_3(CGAL::ORIGIN, 2.0f)); // Criteria Facet_criteria facet_criteria(30, 0.25, 0.05); // angle, size, approximation Cell_criteria cell_criteria(3, 0.25); // radius-edge ratio, size Mesh_criteria criteria(facet_criteria, cell_criteria); CGAL::Geomview_stream gs; char ch; C3t3 c3t3(CGAL::make_mesh_3<C3t3>(domain, criteria)); std::cout << "Triangulation Statistics" << std::endl; std::cout << c3t3.triangulation().number_of_vertices() << " vertices." << std::endl; std::cout << c3t3.triangulation().number_of_cells() << " cells." << std::endl; gs.set_wired(true); gs << c3t3.triangulation(); std::cin >> ch; gs.clear(); typedef CGAL::Triangulation_3<K> Triangulation_3; Triangulation_3 triangulation; copy_tds( c3t3.triangulation().tds(), triangulation.tds(), c3t3.triangulation().infinite_vertex(), triangulation.infinite_vertex()); std::cout << "Triangulation Statistics" << std::endl; std::cout << triangulation.number_of_vertices() << " vertices." << std::endl; std::cout << triangulation.number_of_cells() << " cells." << std::endl; gs << triangulation; std::cin >> ch; { std::ofstream output("tri.out"); output << c3t3.triangulation(); } triangulation.clear(); { std::ifstream input("tri.out"); input >> triangulation; } }
tri.out
Description: Binary data
- [cgal-discuss] Copying two different triangulation types., Simon Perkins, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Sebastien Loriot (GeometryFactory), 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Sylvain Pion, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Simon Perkins, 01/28/2010
- Re: [cgal-discuss] Copying two different triangulation types., Laurent Rineau (GeometryFactory), 01/28/2010
