cgal-discuss - Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function
  • To:
  • Subject: Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function
  • Date: Fri, 5 Feb 2010 13:15:23 +0100
On Friday 05 February 2010 10:47:30 Sylvain Pion wrote:
> It has been renamed to "determinant" (in <CGAL/determinant.h>).
> Note that this particular function is not documented. You may prefer
> to use the documented interface if you expect your program to continue
> to work in the future (not that we never break the API, but certainly
> the probability of a change in the undocumented part is definitely higher).
One another difference it that if we ever break the API of a *documented*
feature, then that change will be announced in the CHANGES file of the new
CGAL release (and the announcement email that I send).
Laurent Rineau, PhD
