Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function
- To:
- Subject: Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function
- Date: Fri, 5 Feb 2010 20:29:44 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=kpKc4COISo4dAIlvhJ0QTT0mi1SQEYjjE1Pa0usaVmVYVrjXZbc0ip8EUtlJakbPBZ 0E9khug0GxmjW7cvZhCyKjcKIyuMlsXYAiGN47S/wBRS1De0apM8aOw7gxwCFElqjnD4 0Scr9G/Gg/fAGk0v6x4r7O54TJt+e6lfrP8UA=
Dear Pion and Rineau,
I've used "determinant" instead of that function, and build the old program successfully.
Thank you.
Best regards,
JJCAO
On Fri, Feb 5, 2010 at 8:15 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Friday 05 February 2010 10:47:30 Sylvain Pion wrote:
> It has been renamed to "determinant" (in <CGAL/determinant.h>).
> Note that this particular function is not documented. You may prefer
> to use the documented interface if you expect your program to continue
> to work in the future (not that we never break the API, but certainly
> the probability of a change in the undocumented part is definitely higher).
One another difference it that if we ever break the API of a *documented*
feature, then that change will be announced in the CHANGES file of the new
CGAL release (and the announcement email that I send).
Laurent Rineau, PhD
- [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function, Junjie Cao, 02/05/2010
- Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function, Sylvain Pion, 02/05/2010
- Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function, Junjie Cao, 02/05/2010
- Re: [cgal-discuss] Compile errors for Filtered_exact.h and CGAL::Failure_function, Laurent Rineau (GeometryFactory), 02/05/2010
