- To:
- Subject: [cgal-discuss] .dll error on CGAL example
- Date: Fri, 5 Feb 2010 17:21:29 +0100 (CET)
Hi there,
i've tried to run a CGAL example (this one):
#include <fstream>
#include <CGAL/Triangulation_2.h>
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_2<K> Triangulation;
typedef Triangulation::Vertex_circulator Vertex_circulator;
typedef Triangulation::Point Point;
int main() {
std::ifstream in("triangulation_prog1.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Triangulation t;
t.insert(begin, end);
Vertex_circulator vc = t.incident_vertices(t.infinite_vertex()),
done(vc);
if (vc != 0) {
do { std::cout << vc->point() << std::endl;
}while(++vc != done);
return 0;
i had no problems building it, but when i tried to run it, i had this:
"It's not possivel to run this application beacuse gmp-vc09-mt-gd.dll was not
found....."
I have this .dll on my CGAL directory, and the other examples work just fine.
Can someone help me?
Best regards
Cristóvão Cordeiro
- [cgal-discuss] .dll error on CGAL example, cristovao_jdc, 02/05/2010
- Re: [cgal-discuss] .dll error on CGAL example, Laurent Rineau (GeometryFactory), 02/05/2010
- Re: Re: [cgal-discuss] .dll error on CGAL example, cristovao_jdc, 02/05/2010
