- To:
- Subject: [cgal-discuss] Polyhedron & OpenCL , mesh processing algorithm
- Date: Mon, 8 Feb 2010 15:00:30 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=Awa0FxfAIi/L+9o0azOb+Mvvm250t4nsL+EYYRx3GO4kMIITCpM8G4A5UmOYVCAiuv 5x1E0imoBXkq3u9pYbVwwfVDSbb5GEOd4Z26BJaFo+MXCeLoljBCa5IpgOzS88jui4D0 5Thi+4+UEeHiUT0o6QSN2qYzusXpRg4Wc1BHo=
Hello all,
I'm in the process of writing mesh processing algorithms that benefit from
OpenCL
the problem is that , in order to process vertices they have to be copied to
gpu , in random access array form
so the only option i can see is first to extract vertex information from the
half-edge , copy them into array , modify them in gpu , overwrite the
halfe-edge point values
but this is really too much overhead and memory usage problem , any one has
a better idea for the process or tackled OpenCL and CGAL before ?
Thanks
OpenCL
Thanks
- [cgal-discuss] Polyhedron & OpenCL , mesh processing algorithm, Mohamed Yousef, 02/08/2010
- Re: [cgal-discuss] Polyhedron & OpenCL , mesh processing algorithm, Priyank Jain, 02/08/2010
