- To:
- Subject: Re: [cgal-discuss] Nef_polyhedron_3 boolean operations
- Date: Tue, 09 Feb 2010 10:49:18 -0800
The .off file format can not represent all Nef3 polyhedra
objects. In particular, if you have a surface with one
or more holes in it, .off format can not represent it.
There is a file format called .nef3 that can represent all
.nef3 objects. The demo program ../dem/Nef_3/nef_3_homgeneous
can read .nef3 objects. It used to be able to write .nef3
objects but that code was removed for some reason. I have
a snippet of code that adds back the "savenef3" command
to the demo program if you are interested.
-Wayne
Laure Guicherd wrote:
Hi everyone,
Is there someone on this ? Because I am meeting the exact same issue. Everything else is working nicely, but sometimes it fails this way, and i have absolutely no idea of the reason for this :(
My meshes are closed and valid, with no self-intersections or "flat" faces.
Any idea will be helpful, thank you very much !
Laure Guicherd
Chris Hamilton wrote:
Previously, I've used the GNU triangulated surface library (libgts), but
I've been having precision issues with that, and am now trying to work
with CGAL. I'm trying to compute the intersection between two closed
and bounded polyhedra.
I'm using Nef_polyhedron_3 with the
Exact_predicates_exact_constructions_kernel. The polyhedra are being
laoded as .off files through the Polyhedron_3 object, converted to
Nef_polyhedron_3 objects, and the intersection computed. Afterwards,
the result is converted back to a Polyhedron_3, and output as an .off file.
All is largely well, except sometimes the process fails with the
following message:
sorry, this triangulation does not deal with
intersecting constraints
This error occurs during conversion back to Polyhedron_3. What exactly
does this error mean? Is there a way I can get the results out as an
.off file?
And on a slightly related question: is there a way to compute the 3d
volume of a closed polyhedron in CGAL? Either via the Nef_polyhedron_3
data-structure, or the Polyhedron_3, as I'd always be dealing with
closed meshes.
Regards,
Chris
- Re: [cgal-discuss] Nef_polyhedron_3 boolean operations, Laure Guicherd, 02/09/2010
- Re: [cgal-discuss] Nef_polyhedron_3 boolean operations, Wayne C. Gramlich, 02/09/2010
- Re: [cgal-discuss] Nef_polyhedron_3 boolean operations, Chris Hamilton, 02/09/2010
- Re: [cgal-discuss] Nef_polyhedron_3 boolean operations, Fred Dorosh, 02/09/2010
