cgal-discuss - Re: [cgal-discuss] Nef_polyhedron_3 boolean operations
  • To:
  • Subject: Re: [cgal-discuss] Nef_polyhedron_3 boolean operations
  • Date: Tue, 09 Feb 2010 16:07:59 -0500
>> Makes sense. However, the intersection of any two closed and bounded
>> polyhedra should itself be a closed and bounded polyhedron, which should
>> be representable by the .off file format. Whatever the degeneracy
>> implied by "intersecting constraints", it should be representable in
>> Polyhedron_3 objects (and hence .off files) somehow, no?
> I'm not sure what you say is true. I can easily come up with two
> .off files which when intersected would not be representable in
> .off format.
Yeah, a little bit of a rash statement on my part. Definitely possible
to come up with counter-examples. However, the whole point of
Nef_polyhedra is to get around these ugly cases (ie: where the
intersection are or contain surfaces, etc). Is it possible for two
nef_polyhedron_3 without holes to produce an intersection with holes?
>> My actual question is this: what does 'intersecting constraints' mean,
>> and why is not representable by Polyhedron_3 objects (and hence .off
>> files)? Is this something that is an error, is this something that is
>> possible but not yet implemented, or is this something that can't be
>> implemented for some reason?
> Good question. Alas, I do not know the answer.
Anybody on this list have any input here?
>>> There is a file format called .nef3 that can represent all
>>> .nef3 objects. The demo program ../dem/Nef_3/nef_3_homgeneous
>>> can read .nef3 objects. It used to be able to write .nef3
>>> objects but that code was removed for some reason. I have
>>> a snippet of code that adds back the "savenef3" command
>>> to the demo program if you are interested.
>> Are these files viewable somehow, or is only the internals of CGAL that
>> can make use of them?
> Yes. The unmodified nef_3_homgeneous program can read,
> intersect, and display both .off and .nef3 files. The only
> thing it can not do (currently) is write .nef3 files. For
> example:
> nef_3_homogeneous loadoff file1.off loadoff file2.off int reg vis
> will read in file1.off, followed by file2.off, compute the
> intersection, regularize it, and then display the result in
> a visualization window.
Excellent. Thanks for this.
Chris
